Will these injectors work?
Old Mar 22, 2016 | 03:09 PM
BauerR's Avatar
BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !
I completely forgot i had these injectors and recently had them cleaned and flow tested.
They're 750cc and high impedance.
Reason I ask, I notice everyone using the long slender Bosch EV style.
Any reason not to use them?
ID:	443440   Click image for larger version
Old Mar 22, 2016 | 09:47 PM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
Do they fit into the fuel rail and lower manifold bosses? Same o-ring OD? Same length as stock? If yes, the I don't see why not.
Old Mar 24, 2016 | 01:10 AM
EvoSpecJBray's Avatar
EvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond reputeEvoSpecJBray has a reputation beyond repute
I would recommend against using these. There are much better injectors available now and even though you have them in your hand, I have had lots of issues with RC in the past. I would recommend Injector Dynamics for any injector needs.
Old Mar 24, 2016 | 09:19 AM
32krazy!'s Avatar
i do like the id injectors but bang for buck the fid injectors are hard to beat. half the cost direct plug in vs using an adaptor or hard wiring a connector. available in 1000 1400 and 2000cc i have seen the 2000cc idle like a stock car with proper scaling and tuning
Old Mar 24, 2016 | 10:41 AM
mdurbahn's Avatar
mdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud of
I think those look alot fatter then the oe ones and from what I remember they are a pretty tight fit.
Old Mar 24, 2016 | 04:43 PM
COBB Tuning's Avatar
COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !
We only use and recommend Injector Dynamics.
If you are going to go through the labor to install injectors do it once and do it right with Injector Dynamics.
bdschet
Mar 30, 2016 01:32 PM
Harris@TPCRacing
Mar 22, 2016 11:41 AM
bdschet
Mar 21, 2016 07:46 AM
Gunny Highway
New Member Introductions
Mar 19, 2016 12:20 PM
