Oil? leak front drivers side
Old Mar 31, 2016 | 01:56 PM
vlocci's Avatar
vlocci is infamous around these parts
Fixed it. Thanks ask
Old Mar 31, 2016 | 03:35 PM
su_maverick's Avatar
su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !
AFAIK, the only fluids like that in the front are the clutch and the brakes. How big is the accumulation?
Old Mar 31, 2016 | 03:41 PM
'02996ttx50's Avatar
agree w either coolant or pentosin emanating from the frunk area..but if you've checked ? you could have a pinhole leak of the drivers side rad(?) the newer iteration of the vw/audi/porsche coolant is pinkish g13 but once 50/50'd its the consistency of oily water and very lightly colored. i'm hunching its pentosin tho..
gl with sorting it out.
Old Apr 1, 2016 | 11:27 AM
only unscientific way to affirm that diagnosis would be if your clutch pedal has no "assist" and feels like a non assisted clutch with engine off. this would indeed point to a failing accumulator/slave or both. in fact it is common to change them both when replacing as their failure is, or can be, concurrent. if it's not holding pressure then it will be stiff at pre startup and eventually ( if not already ) you'll indeed see fluid migration to the master cylinder reservoir in the frunk. it will literally seep out of the canister and flow wherever gravity will take it. it can even seep into the cabin under the steering column. i'd be fairly diligent about sourcing it too. pentosin has nasty consequences when in contact with rubber or the like. gl w it.
Old May 27, 2016 | 12:24 PM
erichb's Avatar
erichb is infamous around these parts
Did you ever figure out what this was? I've got the same symptoms, looking through the front grill looks like it's from the AC condenser but I haven't taken the bumper off yet.
Old May 27, 2016 | 02:24 PM
BLKMGK's Avatar
AC condenser would be compressor oil, AC still work?
MadWhip
Feb 21, 2015 05:23 PM
BiteEmNBeatEm
Jan 13, 2014 10:08 PM
kdog126
Cayenne
Jan 8, 2014 01:59 PM
acelucas
Jun 25, 2013 08:44 PM
82targa
Jul 22, 2008 07:44 PM
