DIY Front diff oil change
Old 04-02-2016, 06:54 PM
magoochi's Avatar
magoochi has a brilliant futuremagoochi has a brilliant futuremagoochi has a brilliant futuremagoochi has a brilliant futuremagoochi has a brilliant futuremagoochi has a brilliant futuremagoochi has a brilliant futuremagoochi has a brilliant futuremagoochi has a brilliant futuremagoochi has a brilliant futuremagoochi has a brilliant future
I've been searching for a while and can't seem to find a DIY for the front diff gear oil change. Anybody know if there is one out there?
Old 04-02-2016, 07:54 PM
Jeanmarcboilard's Avatar
Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !
Step 1: Drain the case.
Step 2: Fill the case.
Haha, seriously, it's a pretty straight forward procedure. I used a little hand pump that screws on the oil bottle to fill it. It looks like a soap bottle pump. I can't remember the volume, it's not much though, maybe 1L. Fill until it comes out of the fill hole.
Old 04-02-2016, 08:15 PM
Yves's Avatar
Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !
I did it as part of my 30K maintenance.
Biggest task is removing some of the panels underneath the car.
You can use this tool :
Amazon.com: Motive Products 1740 Power Fill Pro 1.5 Fluid Transfer Pump: Automotive Amazon.com: Motive Products 1740 Power Fill Pro 1.5 Fluid Transfer Pump: Automotive
Old 04-03-2016, 05:59 AM
jpflip's Avatar
If you are a Renntech member you can get access to a DIY here: http://www.renntech.org/forums/tutor...l-replacement/
Old 04-03-2016, 06:56 AM
magoochi's Avatar
Thanks guys ...I mainly needed to know how much gear oil I will need. I already did the trany and only have 1 quart left. Looks like I will need +/- 1.5 Qt. to do the front Diff.
Old 04-03-2016, 07:43 AM
jpflip's Avatar
I did the transmission and the front differential with 5 1/4 litres. I think 1.5 litres is needed for the diff. You will need a 17 mm wrench (socket) for the plugs, of course do the fill first in case you cannot take it off. My drain plug was magnetic and had a little bit of shaving.... Torque for both plugs, 21 ft/lb. Note: no sealing rings on any plugs on this diff.....
Old 04-03-2016, 11:58 AM
Ronny-'s Avatar
Ronny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud of
Old 04-03-2016, 07:26 PM
Atrox's Avatar
Atrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud of
Same process for 996 tt, no need to remove the spoiler though.
Old 04-04-2016, 04:42 PM
magoochi's Avatar
Thanks everybody,
Old 04-05-2016, 09:46 AM
StealthRide's Avatar
StealthRide is on a distinguished road
I used 5 liters to do the front diff and manual transmission on my 996 turbo. About 1.5 liters of this was used for the front diff. Please ensure you use the correct specification transmission oil for your vehicle - lots into about that online
Old 04-05-2016, 09:56 AM
fishercs's Avatar
fishercs is on a distinguished road
What fluid brand has everyone used for this? A birdie told me Redline makes a superior product to O.E
Old 04-05-2016, 10:42 AM
Olemiss540's Avatar
Olemiss540 is on a distinguished road
I just bought Motul Gear 300 75w90 as it had VERY close specs to the OEM fluid. Not installed as of yet,
Old 04-05-2016, 12:53 PM
I used Motul Gear 300 75w90, there are 2 types as they also do a 'LS' version which is for cars with a LSD make sure you don't get this version if you don't have a LSD
Old 04-05-2016, 01:51 PM
Olemiss540's Avatar
Everything drive/sound fine after switching? Looking forward to the switch myself and have heard no negative reviews to date. Rear the Delvac runs heavier and can cause notchiness/stiffness in the tranny when cold...
Old 04-05-2016, 01:54 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
any quality 75w90 GL-5 is good in front diff.
Quick Reply: DIY Front diff oil change
