PCCB front brakes... expensive suckers
I see tirerack.com has a number of PCCB pad options as well.
http://www.tirerack.com/brakes/resul...oModClar=Coupe
One of them is only $66 a pair but most others are in the $136 ~ $150 range which seems the more common going rate for a front pair of PCCB pads.
As for the 997.1 steel rotors, why 997? Are my PCCB rotors larger in diameter than the regular 996 steel rotors? If I do go that route it seems I need to find pads that will work though. The 996 steel and 996 PCCB brakes have different calipers. Are my PCCB calipers the same as regular 997 calipers?
FWIW, I'm largely sure those Tirerack options are incorrectly described, they fit PCCB pad shape but not PCCB-safe compound. Make a few emails and get it on record they are safe for your discs....
997.1TT steelies shares the same disc offset as 996TT and come in 350/350mm size, PCCB on 996TT and GT2/3 is 350/350, 996TT steel is 330/330
997TT front caliper shares pad shape with 996 PCCB front caliper, rears are completely different
What are my options for the rears to get steel in there?
Goodplan! Don't want to take chances with the PCCB discs...
For steel conversion, can run 997TT discs front and rear...any 350mm rear disc from the 996/997 'family' is good. For pads,(front and rear) anything that fits a 996GT2 or GT3 is what you want.
Okay, thanks! What was freaking me out was seeing different part numbers between 997.1 and 997.2 for lugged wheels. I'll try to sort it tonight so the spreadsheet is clear - I don't want anyone potentially buying the wrong rotors based on something I've made public
That's probably why BLKMGK is finding two part numbers. The original one and the new superseded part #.
the main reason for the pccb on steel is the brake dust. its insane how much dust is genereated with all the pads out there. i have tried 3 different kind all say "low dust" and i cant even make it 1 hr to a car show without dust everywere. i use the ceramic pads and its a lot cleaner. i just hate the dust on super clean wheels
