Impressions-new mounts
Old Apr 19, 2016 | 10:47 PM
louisifis's Avatar
louisifis has a spectacular aura aboutlouisifis has a spectacular aura about
Inserts
Yes, I did consider inserts from various companies. The reason for not going that route was mostly to do with NVH levels. With the ss engine mounts, I was afraid with both engine and ss trans mount, the NVH would be too much for me. So, I think I have a good compromise. See solid engine mounts with a stock, modded trans mount, similar to the window weld MOD. NVH levels are a tiny bit more from the end mounts,and I noticed no increase with the trans mount.BTW xmaciek, I just bought a second hand 997 Tubi muffler( internal X pipe design) I am going to try to adapt to my car, how do you rate the sound...volume and quality??
Old Apr 20, 2016 | 03:59 AM
louisifis's Avatar
Yes, I did consider inserts from various companies. The reason for not going that route was mostly to do with NVH levels. With the ss engine mounts, I was afraid with both engine and ss trans mount, the NVH would be too much for me. So, I think I have a good compromise. Semi solid engine mounts with a stock, modded trans mount, similar to the window weld MOD. NVH levels are a tiny bit more from the engine mounts,and I noticed no increase with the trans mount.BTW xmaciek, I just bought a second hand 997 Tubi muffler( internal X pipe design) I am going to try to adapt to my car, how do you rate the sound...volume and quality??
Old Apr 20, 2016 | 09:30 AM
xmaciek82x's Avatar
xmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant future
Hey louisifis, the sound is deep. I can't say if the deep sound is because of headers or the actual Tubi mufflers. I recently bought the car with the full exhaust on it so don't have much to compare to. I personally love the sound. After hearing multiple 996tt with various exhausts, I was worried that the turbos mess with the exhaust tone too much. The tubi exhaust puts off a right amount of turbo spool noise (nice little whistle) under regular driving, and gets very deep and loud at higher RPMs.
I'm not trying to start an exhaust war/debate in your thread, but to ME, the full Tubi exhaust is the best one I heard so far.
I drove the car 1300 miles when I bought it from FL to IL and the exhaust didn't bother me a bit.
Old Apr 20, 2016 | 05:30 PM
juanbenae's Avatar
juanbenae is infamous around these parts
find it amusing that drivers are so concerned with cabin noise, yet will install an after market exhaust that in most cases louder than stock equipment. my car is not a daily driver so when I do drive it the radio is generally off to enjoy the motor and other mechanical sounds that a fine sports car can provide. then again my last 911 was a tin car that required ear plugs to drive...
Old Apr 20, 2016 | 09:55 PM
louisifis's Avatar
Juanbenae, there is right noise and wrong noise.
A great exhaust=the right noise
Excessive drone/mechanical chatter/grinding/clunking=wrong noise.
Merely my humble opinion.
Xmaciek, thanks for the feedback. Looking forward to playing with the Tubi and seeing what sound I can get out of it.
Old Apr 21, 2016 | 10:20 AM
clsund's Avatar
clsund is infamous around these partsclsund is infamous around these parts
Man, mods/repairs seem like they're never ending! Add another item to the list! haha
Old Apr 23, 2016 | 03:19 PM
juanbenae's Avatar
when I went to the SS trans & motor mounts I had nothing in the way of wrong noise IMHO... I think concerns are over stated in most cases when owners consider the upgrade. I would think the window weld might transfer more noise than say the tarret street tranny mounts. imagine a very large skateboard wheel, very cushy. if the window weld product im thinking of is what's used that would create a more solid opportunity to transmit noise, vibration, and wrong noise in my estimation.
Old Apr 23, 2016 | 04:23 PM
'02996ttx50's Avatar
i agree. i think there are few for whom the window weld mod will be advantageous enough to justify the added nvh. i suspect ( and have driven ) cars with the TS inserts and they are fine. perhaps the window weld mod adds a similar addition of nvh.
but for most, semi solids in conjunction w a new 997 t-mount is more than sufficient. though i can see adding the TS t-mount inserts myself. my car is one toke over the line, as it is anyway. so some poly inserts aren't gonna be an issue.
stevepow
Jun 21, 2019 04:22 PM
R33_
Nov 30, 2016 04:59 PM
mep1811
Cayenne 958
Mar 30, 2016 08:08 AM
nvelicu
Mar 26, 2016 11:56 AM
Polar993
Mar 24, 2016 01:04 PM
