What could still be causing wheelhop?
Old Apr 22, 2016 | 01:48 PM
TabooPc's Avatar
TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !
Question What could still be causing wheelhop?
Hey Guys,
I recently discovered my stock coil-overs were completely shot (Literally no dampening). I upgraded to Ohlins Road & Track. I've always had wheel hop, so I figured this would fix the problem, but no dice.
The car still hops violently when I dump the clutch from 4500 rpm.
I'm looking for advice on what to upgrade next to try and eliminate this terrible wheelhop...
Suspension Upgrades:
- Ohlins road and track coils
- Full monoball ERP toearms and dogbones
- Torque Semi-solid engine mounts
- Semi-solid trans mount
I think the only thing I don't have is the control arms. Could this be the cause? My understanding was that toe flex is what caused wheel-hop.
Thanks in advance for any advice!
Old Apr 22, 2016 | 02:46 PM
nitrorocket's Avatar
nitrorocket is infamous around these parts
What is the rear toe settings on your back tires right now?
Old Apr 22, 2016 | 03:06 PM
Sveach756's Avatar
Sveach756 is infamous around these parts
I have yet to drop the clutch in my Porsche guess I'm still new.
Old Apr 22, 2016 | 04:05 PM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
owned many AWD cars, turbo, Eclipse GSX, 2x evos - Audi s4, To be honest I never launched my car yet. LOL i feel like something will take a BEEEEP when i do that, (i have a feeling that i will destroy something..) - so I take off with feelings - plus my clutch wants to destroy my chin, engages high and HARD.
Old Apr 22, 2016 | 05:25 PM
32krazy!'s Avatar
unbolt the cardon shaft and try a launch. the wheel hop may be the front wheels hopping not the back
Old Apr 22, 2016 | 05:52 PM
TabooPc's Avatar
Its definitely the rear. My car is a gt2, so it couldn't be a traction issue with the front wheels, as they're not powered.
I think we use our cars for very different things then. I would advice against dumping the clutch without some experience.
0.14 degrees on both sides. Could that be the cause?
Old Apr 22, 2016 | 06:01 PM
32krazy!'s Avatar
sorry didnt realize it was a gt2 try raising the air pressure in the tires. my d/r will hop if they get to low. to much stickyness
Old Apr 22, 2016 | 06:32 PM
TabooPc's Avatar
No worries! I'll give that a shot. I run my r888's at about 28-30psi on the street. Ill give 36 a shot
Old Apr 24, 2016 | 09:45 AM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
I had wheel hop when i put my tires at low 30psi all around. When i put them back to 36psi in the front and 40psi in the rear with no wheel hop.
Im running r888.
Old Apr 25, 2016 | 09:48 AM
SamboTT@ByDesign's Avatar
Hey Max, try 34-36 and soften the rear for extreme launching stuff. Tires and suspension are fighting eachother.
Old Apr 26, 2016 | 01:07 PM
stiffness of rear shocks. get solid bearings and solid pucks for rear lower control arms. check toe specs.
#TeamAIM
Old Apr 26, 2016 | 01:42 PM
Macster's Avatar
Originally Posted by TabooPc
Hey Guys,
From what I recall curing wheel hop in cars equipped with solid rear axles was hard. It often required ladder bars to prevent axle twisting.
With the advent of IRS wheel hop was a real pain. I used to know a couple of guys who street raced a Corvette, circa a 1969 MY. The car's factory engine was removed and a larger displacement engine and with some mods to allow the engine to really put out the HP was installed in its place. Wheel hop, in fact drive train longevity, was a real problem. Eventually the owner tired of the expense and had the mod'd engine removed -- a friend of mine installed it in his early Firebird -- and had a stock engine, 396ci IIRC, installed and put an end to his street racing days.
I have only "dumped the clutch" a few times -- total -- with my Boxster, GTO, and Turbo all of course fitted with IRS.
With all 3 the clutch was dumped with sufficient RPMs that the rear tires broke loose. Thus there was no wheel hop.
If you just want to dump the clutch and avoid wheel hop raise the RPMs at which you dump the clutch. The idea is you break loose the rear tires and can modulate the throttle to control to some extent the amount of traction so the car just doesn't sit and spin its rear tires, unless of course this is what you want to do.
If you want to effect an efficient launch I think you are probably going to have to develop a new launch technique that avoids not only wheel hop but also excessive wheel spin. It will almost certainly exact a toll on clutch life.
What contributes to wheel hop is the normal give the suspension has from the rubber (if stock) bushings. Even aftermarket firmer bushings have some give or the car would ride like a covered wagon.
Since most owners seek better handling, better tire grip, a lower car for cosmetic reasons, most suspension mods are geared towards those objectives. Controlling wheel hop, dealing with wheel hop, is not a concern because it doesn't occur because of the way the cars are driven, how they are used.
Visit a drag strip and observe 996 Turbos or just 996 Carrera cars how they launch. Pay particular attention to the cars that launch without wheel hop. Observe how they are launched. Then seek out the car in the pits and ask the owner/driver what he has done to quell wheel hop.
Old Apr 26, 2016 | 05:30 PM
Fadi's Avatar
Fadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond repute
r888 wheel hop easily, if running 30 sidewall than I dont know if anything to be done to avoid wheel hop. I would try some DRs or bigger sidewall if you want to address tire and not suspension
Fadi
May 15, 2016 11:24 PM
OldDog
Mar 28, 2016 05:22 PM
nvelicu
Mar 26, 2016 11:56 AM
albert@velosdesignwerks
Mar 24, 2016 03:41 PM
Mar 24, 2016 03:26 PM
