Hesitation/miss under load
Old Jun 5, 2016 | 10:44 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
While I prefer the stock copper plugs, have had a couple 6tt's come in running NGK and Denso Iridium's without issue, you should be fine
Originally Posted by bushrat
Bought a set of iridium plugs.....ran them in my 930 with no issues
Old Jun 5, 2016 | 10:45 PM
bushrat's Avatar
bushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond repute
Great....thanks
Old Jun 5, 2016 | 10:48 PM
bushrat's Avatar
Gap @ .034?
Old Jun 5, 2016 | 10:54 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
.040 well maybe k24 turbos but for my level i cant run those gaps. To wide of a gap for me and my tuner.
Old Jun 5, 2016 | 10:58 PM
bushrat's Avatar
04 996tt X50 stock
Old Jun 5, 2016 | 10:59 PM
996tt550hp's Avatar
Here you go everyone says .026 to .028
https://www.6speedonline.com/forums/...o-out-box.html
Old Jun 5, 2016 | 11:36 PM
bushrat's Avatar
So be it....thank you.
Old Jun 6, 2016 | 06:42 AM
996TTFTW's Avatar
996TTFTW is infamous around these parts
I'll second checking the Maf. Mine went and I had terrible misfire under load. no lights on the dash. When I pulled the Maf it ran perfectly but with the ABS/PSM lights on. I cleaned the Maf but when I put it back in it wouldn't recognize it so I replaced it. Runs great now.
Old Jun 6, 2016 | 07:18 AM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
Most tuners and experts over here chose NGK PFR7B plugs and NGK coils.
Never heard of any car missfiring with these suckers.
Old Jun 6, 2016 | 08:01 AM
993GT's Avatar
a more recent threads we talked about this...https://www.6speedonline.com/forums/...parkplugs.html
https://www.6speedonline.com/forums/...-tuned-tt.html
Old Jun 6, 2016 | 08:02 AM
993GT's Avatar
That would probably be good, be careful gapping them, do not damage the centre electrode
Gap @ .034?
Old Jun 6, 2016 | 08:31 AM
'02996ttx50's Avatar
most plugs that are to be used in this car are pre-gapped. that said, i am told and always use .027 w OEM Bosch FR6LDC for a tuned tt.
the more important aspect is the heat range & gap, less so the brand of plug as long as it is regularly used in this car. so ngk/denso/bosch/beru all ok. just make sure they are a "6" and recommended for the car.
from that other thread and "tony" from EPL
".026-.028If you plan on running more then 1.2 bar , gap them a little tighter."
Old Jun 6, 2016 | 09:27 AM
bushrat's Avatar
Have a new maf on order....just one of the maintenance parts suggested to replace @ 55k miles. Will be removing engine/tranny this winter to fix everything.
Old Jun 6, 2016 | 10:11 AM
That thread does not help much.
Old Jun 6, 2016 | 03:58 PM
split71's Avatar
split71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond repute
Originally Posted by pwdrhound
I've always put the in the OEM plugs without touching them. Never any issues...
Bingo. Exactly what I did.
