Dashboard squeak and rattle
Old Jun 6, 2016 | 05:27 AM
Timothykee's Avatar
Timothykee is infamous around these parts
My 2002 tiptronic TT has developed a loud squeak and rattle which appears to be coming from the bottom of the windshield where it meets the dashboard. When the car goes over rough surface the rattle appears but not with smooth road.
I have removed the glove box, instrument cluster, the factory infotainment cluster, the 3 plastic panels covering the battery, and the noise still persists. I have ordered the foam cord and will try stuffing it into the windshield trim. All wires and hoses in the battery compartment seems to be tightly secured.
After removing most of the movable parts in the cabin, i am starting to guess it maybe due to bad bushings of the suspensions, or it maybe the condenser of the air conditioning system getting loose? Can anything in the HVAC get loose and make such noise?
Anyone has similar experience and found a cure at the end? I love driving the car but these noise is taking away a large part of the fun.
TIA!
Old Jun 6, 2016 | 08:41 AM
'02996ttx50's Avatar
screws in the speaker enclosure?
though i suppose would "rattle" not "squeak".
Old Jun 6, 2016 | 07:37 PM
gregp714's Avatar
gregp714 has a spectacular aura aboutgregp714 has a spectacular aura aboutgregp714 has a spectacular aura about
Had a similar issue recently and found a post on Rennlist that suggested using a flat blade to lift the weather seal on the outside of the windshield and then squirt bicycle chain wax under the seal.
I used White Lightning Clean Ride. It worked for me.
Old Jun 6, 2016 | 07:54 PM
HotRodGuy's Avatar
i went looking, couldn't find it. But I think this is where mine comes from
Old Jun 6, 2016 | 08:19 PM
gregp714's Avatar
https://www.6speedonline.com/forums/...tion-help.html
My mistake. I thought it was Rennlist.
Old Jun 7, 2016 | 05:04 PM
Timothykee's Avatar
I have tried stuffing a 6mm rubber cord beneath the windshield trim outside, around the glass except the bottom but it disnt work. About the chain wax, should it go to the top or bottom of the glass?
I removed the a/c duct that is right on top of the driver footwell, it eliminated some of the noise feom the centre console but the loud metallical rattle still persists from underneath the driver side dashboard. Really cant see anything inside the cabin that would make such noise. It aounds like a box of coins vibrating.
This is driving me insane!
Old Jun 7, 2016 | 05:32 PM
HotRodGuy's Avatar
thanks!
semicycler
Jun 30, 2016 07:39 AM
Fuzzo
Cayenne 955/957
Mar 30, 2016 08:06 PM
SPEC V
NY Tri State
Mar 29, 2016 05:40 PM
krikra
Mar 24, 2016 08:08 PM
