Maf-less guys running BOV's. Are you getting vacuum from the factory location?
Old Jun 21, 2016 | 09:25 PM
awdbiturbo1's Avatar
awdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant future
I'll most likely keep the valve plugged in and cap it, I will speak to my tuner to verify this and what he would like to do. I'll get vacuum for the tial BOV's directly from the manifold as well as the FPR. Thats Pretty clear and obvious. What about the other factory vacuum lines anything else you can think of i should changed, cap or re-route?
Old Jun 21, 2016 | 09:27 PM
I was also told to cap the oil reservoir/tank where it would normally go to the plenum as well as the venturi tube where it connects to the y-pipe. Does this all make sense.
I am finishing up the car nearly ready to put the motor back in and would rather do all this stuff before it goes back in.
Old Jun 21, 2016 | 09:32 PM
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
Ok for the vacuum delete stuff, unless you're going to remove the secondary air pump like I did, a total vac reduction is not worth it.
As for the tank, you will want to leak the line going from the plenum to the tank but you can get rid of the tube to the intake pipe and use a breather similar to what I did.
Old Jun 21, 2016 | 09:36 PM
I should have deleted the SAI but i didnt, Maybe over the winter (motor build) I have a breather filter on the drivers side of the oil reservoir, What i am talking about is the nipple that would connect to the top of the plenum ( directly in front of you looking into the engine bay)
Old Jun 21, 2016 | 09:40 PM
flewis763's Avatar
Ya you want to leave that on. That sucks extra pressure out of the tank when the engine is under vacuum. It's plumbed into the turbo oil drain reservoirs to and suck any extra oil in the reservoirs. I'd suggest keeping it.
Old Jun 22, 2016 | 09:23 AM
Enclavet's Avatar
Enclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to behold
Did you get a code when deleting the n249? I assume you kept the electrical connector plugged in?
No code.
Old Jun 22, 2016 | 10:23 AM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
^^ I got a code. I removed the solenoid altogether though....thinking about putting it back in just to clear it.
Old Jun 23, 2016 | 07:49 AM
I was told to plug that, I wonder if it will work right? My plenum only has two nipple fittings on the top.
Curves4S
May 29, 2004 02:03 AM
gregy
May 26, 2004 12:06 PM
bond
May 13, 2004 12:34 PM
nova996
Nov 14, 2003 05:21 AM
aracerx
Aug 6, 2003 11:55 AM
