Clutch pedal
Old Jun 28, 2016 | 06:05 PM
Greehn's Avatar
Greehn is infamous around these partsGreehn is infamous around these parts
Clutch pedal
Hey.
I'm have some issues with the position of my clutch pedal. It's not going all the way back, so my cruise control won't engage cause the cc switch is not pressed.
This happened after I installed new clutch disc and PP. Sachs 2,5.
https://www.sachsperformance.com/SACHS-Performance-Clutch-Cover-999764
https://www.sachsperformance.com/SACHS-Performance-Clutch-Disc-001098
I have the original clutch system, not GT2.
I've done a lot of work to find any faults. But I'm not finding any, so have any of you experienced this after changing to a non original clutch?
Old Jun 28, 2016 | 07:48 PM
wross996TT's Avatar
Have you bled the system...multiple times?
Old Jun 28, 2016 | 08:25 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Yup you need to re bleed the clutch. It happened to me.
Old Jun 29, 2016 | 02:44 AM
Greehn's Avatar
I've bled the system twice, but I will try a few more times then.
Old Jun 29, 2016 | 10:42 AM
Third-Reef's Avatar
Third-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond repute
Do you still have the pedal assist spring in there? I have read about removing it for better pedal feel but it also causes the pedal to not return fully and the switch needs to be shimmed to compensate for it
Old Jun 29, 2016 | 12:06 PM
Greehn's Avatar
I disconnected the master cylinder, and that resulted in the pedal going all the way. So im wondering if there's something wrongs with the master cylinder, because I'm unable to pull far enough out. And since I disconnected it from the pedal, there's nothing hindering it on pedal-side.
My thought is that since I'm not able the pull the master cylinder far enough out with my hands, it seems that it is the
problem.
Thoughts?
Ronny-
May 13, 2020 03:11 PM
Drifter911
Dec 11, 2016 11:38 PM
speedracer800
Jun 27, 2016 11:58 AM
bobolouie
Apr 27, 2016 08:38 AM
GT650-25
Apr 18, 2016 09:51 AM
