Help with Seat Mounting
The seat bottom easily pops off so you can remove that wire.
this should help others that need to remove the receptacle
http://gallery.rennlist.com/gallery/albuq41
if you have an airbag light you now need a dealer or shop with pwis to turn it off. possibly durametric pro will do it. thats why its critical to unplug the battery until all the plugs are reconnected
Yea - live and learn - have a Durametric and a shop to do it if it doesn't work. Thanks for the help again.
I've heard good things about Wedge Engineering.
http://wedgebrackets.com/porsche-996...-brackets.html
If you're ok with no adjustment and like it low, the BK floor mount works great with side mounts. My 34 inseam works perfect with gt3 buckets mounted to the floor, gave the passenger a recaro slider.
