No Start After Heavy Rain/ changing of seats
Old Jul 26, 2016 | 08:28 AM
Jferrante's Avatar
Jferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant future
I know this topic has been discussed before but my car didnt start this morning after a heavy thrunderstorm last night. All dash lights and no cranking of the starter. Letting her dry out today and will check again tonight; assuming some electrical contacts got wet.
The only caveat is that I was installing seats and a rollbar yesterday before the rain - do any of the electronics under the seat effect ability to start? I am assuming no but figured I would ask.
*edit - the car is registering 12v on dash meter - also the key fob wont work to open frunk - interior frunk release not working either.
Old Jul 26, 2016 | 08:42 AM
splitime's Avatar
splitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond repute
Door open the entire time for rollbar/seat install, could have been the battery drain that broke the camels back?
Old Jul 26, 2016 | 08:47 AM
Jferrante's Avatar
registering 12+ volts on the dash - the key fob is also not working - couldnt pop the frunk - even the controls inside didnt work to open it.
Old Jul 26, 2016 | 09:13 AM
Lennon31987's Avatar
Lennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond repute
nothing under seat should affect, plug in 12v porsche charger, pop frunk, check batt.
Old Jul 26, 2016 | 09:47 AM
wross996TT's Avatar
Actually the immobilizer may be under the seat (it is in a cab). If this is fried, you won't be able to start the car.
Old Jul 26, 2016 | 09:50 AM
Jferrante's Avatar
Not a cab - just stopped home for lunch to try and get the funk open - tried to jump through fuse box nothing - pulled front right wheel well and couldn't find the lever to open it.
I did find this wire in the rear seat area that must have come unplugged during bar install.
Could this be my issue what does it go to?
Old Jul 26, 2016 | 09:51 AM
Jferrante's Avatar
Had trouble popping frunk - jumped through fuse box and even pulled front fender liner - will try again after work
Old Jul 26, 2016 | 11:08 AM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
that plug looks like bose sub
Old Jul 26, 2016 | 11:09 AM
Jferrante's Avatar
Very well could be since I pulled a box out of the rear.
Old Jul 26, 2016 | 11:18 AM
Jferrante's Avatar
you might be getting to something here - did some quick search on this and found this -
Old Jul 26, 2016 | 12:01 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
That plug goes into your bose sub. Get a code reader and see what the faults say. Sounds like an alarm problem.
Old Jul 26, 2016 | 12:02 PM
Jferrante's Avatar
Yea looks like the immobilizer - may not have tranferred all the necessary harnesses from the stock seat.
Old Jul 26, 2016 | 12:53 PM
Jferrante's Avatar
Can anyone confirm everything that needs to be plugged in for the immobilizer to function correctly?
Old Jul 26, 2016 | 04:41 PM
Macster's Avatar
Not sure of the connection but there is an antenna behind the ignition key surround that is used to transmit an RF signal to the key's RFID pill which energizes the pill and in turn it responds with its RFID that is then decoded and if found in teh security system key ID table lets the engine crank.
There is another antenna -- not sure where -- in the A-pillar? -- that picks up the key's RF signal that is sent to unlock/lock the doors or front trunk.
Not sure where these antenna connections go to -- maybe not directly to the security module -- but they have to go to a device that receives the RF energy and decodes it and then transmits the digital data to the security module.
Thus, and I think this has already been offered by others, some connector is not connected at the security module. That's all I have...
Old Jul 26, 2016 | 07:21 PM
Jferrante's Avatar
Good news everyone - the immobilizer wasn't fully plugged in. Simply pushed it in and started up. thanks for the help
