Which screw goes where?
Old Aug 12, 2016 | 07:01 PM
hodie21's Avatar
hodie21 is infamous around these parts
So I finally got all my hoses and parts in for my radiator swap. I'm putting it all back together now and there are 2 different types of Torx screws for the car.
So where do each type go?
One has a built it washer/spacer type thing.
ID:	456211   Click image for larger version
Old Aug 12, 2016 | 07:23 PM
Macster's Avatar
Can't tell where exactly the screws go but the one in the 2nd pic has a shoulder.
This is used to align whatever the screw goes through a diameter -- a shoulder -- to fit to. This helps locate whatever the screw goes through more accurately, precisely, and generally more securely.
You have to look at what the hole looks like. If it is about the same diameter as the threaded portion of the screw the 1st screw is used.
If the hole diameter is larger or there is a diamete for the screw's shoulder to fit into, the 2nd screw shoud be used.
Old Aug 12, 2016 | 11:15 PM
Samplus's Avatar
Samplus is infamous around these parts
front or rear bumper screws...
Old Aug 12, 2016 | 11:21 PM
uschoice's Avatar
uschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant future
Just about to say the same thing.
Check your bumper for missing screws including inside the fender.
Old Aug 13, 2016 | 05:18 AM
hodie21's Avatar
Are the shouldered ones the bumper screws?
Old Aug 14, 2016 | 06:20 AM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
I know the one with shoulder goes in the fender - top. also the one with the shoulder will have an larger opening
illusionist810
Bentley
Jul 21, 2018 05:16 PM
EstorilM
Aug 17, 2016 01:05 PM
EM 996 GTS
Mar 6, 2004 08:05 PM
luting_chen
Oct 9, 2003 12:58 PM
Pistol
Sep 27, 2003 02:36 PM
