Silver bullet build (updated)
Old Jul 5, 2016 | 07:39 PM
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
Well guys, my build is finally off to get tuned. So excited.to see the results soon.
It's been a struggle to get it done. Between being parts, time working away from home, fitment issues with stuff, and just the time to do the work. Lots of 16 hour days on a day off from regular work to finish it up.
I'll keep the updates coming as the tuning is being done. Here is the mod list the best I can't remember.
Engine:
Pinned coolant lines
Vac reduction, secondary air pump delete
Ipd plenum with 74mm tb
Custom fuel system, dual walbro 450 pumps, -8 an supply line, -6an return, 1300cc injectors, flex fuel sensor, fuelab fpr and filter
K20/billet 20g turbos ported
Ported manifolds
Catless 3inch x pipe exhaust
3 inch y pipe
4.5 inch srm intercoolers
Proefi 112 stand alone ecu
Torque solutions motor mounts
Gt3 dipstick conversion
Evap system delete
Filters on turbos
Transmission
Exedy triple carbon r clutch
Oem gt2 slave conversion
Wavetrac lsd
Poly bushing mounts
Shift lever counter weights removed
Suspension
H&r coilovers
Eibach adjustable sway bars
HD adjustable end links
Solid thrust arm bushings front and rear
Poly lca bushings front and rear
Poly toe link arm bushings
Lockout plates
Solid rear subframe bushings
Adjustable dog box arm with solid heim joint ends
Brakes
997 tt 350mm rotors
Spacers for stock calipers
Rpf 600 fluid
Ss lines
Body.
Side radiator bracket mod and relocate
Modded fender liners
Joe toth gt2 canards
Rolled and pulled fenders
Rennline front screen kit
Wheels
Forgestar cf10
19x9+40
255/35/19 re-11
19x12+40
325/30/19 re-11
There is more stuff I forgot I'm sure.
Old Jul 5, 2016 | 09:13 PM
vogz's Avatar
vogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond repute
Looking good! Getting any rubbing with that tire setup?
Old Jul 5, 2016 | 11:34 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Doh!!!! didnt build the motor? You will have to lower your torque alot and i wouldnt go past 600awhp. Anything passed there is a ticking ticking bomb.
Just my 2 cents.
Old Jul 6, 2016 | 12:10 AM
BLKMGK's Avatar
Just my 2 cents.
It's torque you worry about, not horsepower. Folks have been running more than 600 for awhile but if you give it full timing midrange there's going to be issues...
Old Jul 6, 2016 | 12:15 AM
996tt550hp's Avatar
Not true a 2001 turbo over here had 2 bent rods and made less then 600awhp. Thats why i built my motor to the teeth so i could go to the max on hp. Rods can break at anytime but the higher u go the more stress you put. Rods are just weak in our motora.
Old Jul 6, 2016 | 12:49 AM
pwdrhound's Avatar
Looks like you did a ton of work. Congrats. When you get a chance, check your idle fuel pressure. Curious what it is with the two 450s cooking along at full bore.
Old Jul 6, 2016 | 04:29 AM
flewis763's Avatar
Just my 2 cents.
It will be up north of 700 rwhp but torque will be limited down to 600wlb. I have 12 psi springs in my gates so it will be set to come on slowly until we hit peak torque around 3500-4k range and then add boost all the way to redline.
Thanks man. Ya I know we talked about this on other pages. Second pump won't come in until 10 psi. It's not perfect but it will work for this year. May go to seans brushless setup next year. I also added that fuel cooler on the return so hopefully thay helps.
It took lots of modding but they do not anymore.
Old Jul 6, 2016 | 06:00 AM
SamboTT@ByDesign's Avatar
Looking good Freddie! And quickly done too!
Old Jul 6, 2016 | 09:20 AM
mdurbahn's Avatar
mdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud of
Cool build, do you know what part # filters you used? They look better then what I am using..
Old Jul 6, 2016 | 09:29 AM
flewis763's Avatar
Thanks. Sadly not as fast as I would have liked. Was trying to have it done by may 1.
It's a k&n rx-3770
Old Jul 6, 2016 | 10:29 PM
BLKMGK's Avatar
At what torque level?
Old Jul 6, 2016 | 10:38 PM
996tt550hp's Avatar
K24 billets he wasnt even close to 600whp or torque. Thats why i built mine so i will not have this issue. Anyone can run any horsepower but stock rods and headstuds are pretty weak. After looking at another motor i see why heads lift. I learned alot looking at the motor apart.
https://www.6speedonline.com/forums/...-bent-rod.html
Old Jul 7, 2016 | 12:49 PM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
Hard to compare the two setups. I'd image that the GIAC tune did not pull out much timing in the mid-range and I would also bet that the boost was tuned to ramp in hard as well right there. Freddy's proEFI tune should be much more effective in controlling the mid-range tqe and how much and when boost comes in. I believe this has been proven by others running big setups on proEFI and stock motor.
Old Jul 7, 2016 | 01:59 PM
DSCOFF's Avatar
DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !
There is certainly a bit of a case by case situation here. You had your experience, but mine was very different.
I had a very similar setup to the OP, but with a hair more HP. The car was taken to many 1/2 mile and roll race events, took frequent trips to Mexico, and then at a lower power setting was daily driven as often as possible. My rods just came out and show no sign of stress/bending. I did the upgrade just so I can go to the next level.
My mentality always was, at the level I had (775WHP on the highest setting) I would be on borrowed time.
Old Jul 19, 2016 | 08:25 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
How is the tuning going?
