Does Tyre pressure affect Viscous Coupling function?
Old Oct 22, 2017 | 06:29 PM
'02996ttx50's Avatar
Originally Posted by TXTurbo996
Even switching to ****ty Hankook Ventus tires with weak sidewalls made my PSM go crazy in turns. But if you're running the right sized tires, a difference in tire pressure shouldn't make enough of a difference unless you're basically running one set overinflated, and the other two basically flat.
i would venture that your experience wasn't an "even when switching to hanko*k ventus" per se. i'd suggest that any psm or squirrelly handling with those tires, was a direct result of those tires simply being inadequate to the task and demands of running on a porsche turbo. you got the flimsy sidewall party completely right.
and on a tangential but related point. any new tires until scrubbed can easily trigger psm intervention, and that said..
i recently put on new rt651's paired with ( new ) michi pss up front ( I'm rwd ) and not a squirrely moment yet, even during the first few scrubs. i ascribe the lack of any unwanted psm intrusions to the quality of the rears.
great tire, the rt651k.
dreamerstudio
Mar 7, 2017 07:38 PM
SheriffDep
Sep 7, 2016 10:46 AM
bebeqq1231
Aug 14, 2016 03:40 PM
