Tire recommendations for 19" rim
Old Nov 7, 2016 | 10:52 AM
rickw30's Avatar
rickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud of
Love the color ! Was gonna order that color back in 2003 but settled on a Seal Grey that had just come in. What size and offset are your rims? Mine are 8.5 and 11.5. Was thinking 295 but it may look a little stretched on 11.5 rims. Was running 315/25 and I liked the width. This is such a headache. Part of me is worried about the front diff as I understand the concept as it pertains to tire sizing. Was hoping that someone out there did some longer term testing with 245/305 setup and checked front diff. Really was hoping to run another set of Michelins (PSS or new PS4) but it does seem like thats gonna happen.
Old Nov 7, 2016 | 12:03 PM
r0nd3L's Avatar
r0nd3L is infamous around these parts
8.5 ET49 and 11" ET40. I agree that on 11.5", 295 will be slightly stretched, but 305 PSS should be perfect. You should consider 255/305 setup if you have clearance in the front.
Old Nov 7, 2016 | 12:13 PM
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
A 255 front is very hard to fit and would not recommend unless your comfortable with modding lots of stuff in the front of your rear. A 245 is much easier to fit.
As for 245/305 combo, it does run fine, just the awd system doesn't transfer much torque to the front wheels. I local guy has run sadly a 235/305, setup on his car for many years with zero issues. I told him he needed to switch to a 245 front next time he gets tires though.
Old Nov 7, 2016 | 04:10 PM
rickw30's Avatar
Im running an 8.5 wth a 53 offset up front. My current 235/35 is awfully close to the spring perch. Do u think a 245/35 will fit. Suspension is stock.
Old Nov 7, 2016 | 04:13 PM
flewis763's Avatar
Ya just put a spacer in. 5mm, 7mm whatever you need to make it work
Old Nov 7, 2016 | 04:49 PM
rickw30's Avatar
How tough is a RWD conversion on our cars. Is yours converted ?
Old Nov 7, 2016 | 07:02 PM
flewis763's Avatar
Well just going to rwd with an open diff is super easy and really costs nothing. You will want to add a diff though and that costs quite a bit for most guys not doing a portion of the work themselves. For a street car, wavetrac is the ticket and are 1250 bucks, for a track car, guardian are the ticket and are 2500+. Then you have install on top of that.
Old Nov 7, 2016 | 07:04 PM
flewis763's Avatar
Also yes I am rwd and run a wavetrac diff in my car.
