350mm adapters
Old Nov 6, 2016 | 08:15 AM
Ronny-'s Avatar
Ronny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud of
350mm adapters
Hi
Does anyone have the measurements on the calipers by hand?
I need the size of the bolt holes and distance between them.
Im supposed to draw the adapters and have them cnc machined.
Are the adapters the same on the front as on the rear?
Old Nov 6, 2016 | 08:21 AM
joey996tt's Avatar
joey996tt is infamous around these parts
THE spacers to use 997/350mm rotors should be 11mm and factory 997 caliper bolts work for this set up. I don't know the other measurements but it may be easier just to purchase the spacers and bolts they are available fairly cheap .
Old Nov 6, 2016 | 09:00 AM
BLKMGK's Avatar
He's in Norway so it's likely that shipping and taxes will kill him, I too would be nterested in measurements. I suppose a caliper could be pulled to measure and gather the info? We're using a stock caliper for this and simply spacing it out half the gained diameter right? Seems 10mm thickness would work? What's the spacing on the caliper bolts center to center?
Old Nov 6, 2016 | 09:05 AM
Ronny-'s Avatar
yeah thats right.. it will run me for 200usd or maybe more for these smal pieces.
So i'd rather have them made up.
My car is in winter storage so having my own calipers measured is not possible right now.
I assumed 10mm thickness would be right, but maybe 11mm is the correct for some reason.
Im planning to 3d print it in plastic first so i know the design is right, before sending the drawings to the company that cnc machine this in aluminium.
But the center to center bolt holes measurements is whats most important.
also the surface area on the hub that sits against the caliper is also relevant as i want this to match up.
Old Nov 6, 2016 | 12:16 PM
joey996tt's Avatar
Yeah sorry type-o the spacers I am running are 11mm and I used 997 turbo factory caliper bolts front and rear.
Old Nov 6, 2016 | 12:47 PM
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
I have it written down in my notes in the shop somewhere. I'll find it here tonight.
Old Nov 6, 2016 | 01:20 PM
Ronny-'s Avatar
Much appreciated!
Old Nov 6, 2016 | 03:10 PM
BLKMGK's Avatar
I'd like to get a set too but some of the prices I've seen are a bit nutty even in the States. I've been told a piece of flat stock of the rig thickness can be drilled to fit but I'm not sure I'd be comfortable going to the local hardware store for this, I'd want decent hardened aluminum. Using the 997 bolts makes sense though
Old Nov 6, 2016 | 03:31 PM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
I use 11 mm. 10mm is working but the distance between the caliper and the rotar is really tight. with 11mm its better of course. But the downside is - dont know anymore if it was at the front or rear - the pads are sitting a tiny little higher than the rotor.
Old Nov 6, 2016 | 03:59 PM
joey996tt's Avatar
Very very slightly from my experiences you have to bevel the top of the pad and everything "breaks" in and wears together perfect. One time I did not and the front made crazy noise.
Old Nov 6, 2016 | 04:01 PM
BLKMGK's Avatar
I thought it was only an issue with pad overlap trying to use 380mm rotors with the stock calipers. The 350mm has an issue too?
Old Nov 6, 2016 | 04:04 PM
joey996tt's Avatar
Yeah stock 996tt calipers w/ 11mm spacers and the 350mm rotors some pads have a very small amount of pad over lap. ATE's seemed to fit well, textars seemed to over lap a little more.
Old Nov 6, 2016 | 05:57 PM
flewis763's Avatar
Front center to center is 142mm, rear is 131mm. You'll want to make the spacers 35mm or 40mm wide, 11mm thick. Bolts are m12x1.5. I use 80mm bolts but the 997 stock bolts are 82mm. 80 has plenty of thread in the hole though
Old Nov 7, 2016 | 12:21 AM
Ronny-'s Avatar
Spot on Flewis763!
On the spacers that are for sale there is a profile, is that just to save weight or are there any other benefits by having it smaler in the midle?
http://cf-design911-3.datadial.info/...TT-425_LR3.jpg
Old Nov 7, 2016 | 12:57 AM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
Ronny, adapters for this and much more från Finland: http://en.9xx-parts.com/category/509/adapterit
