Dive Planes for 996TT
I prefer not to put any holes in the bumper. Would it make sense to run a bead of silicone on each side in addition to the double sided tape.
Was at VIR 2 weeks ago with several PCA BS'rbuddies. One has a GT4 with dive planes. He used D/S tape only & one of the CF dive planes came off at 150 on the back straight. Thankfully it flew out in the grass and was unhurt. He was able to find the end of the day.
Interesting. My question would be what type of DS tape did Mr. GT4 use? Not any tape will do. 3M VHB is the only one that is recommended. Second question, did he have the clear film on the bumper, and did he stick it to that? Third question would be, how did he clean off any wax or other treatment from the car and how did he clean the back side of the dive plane? The surfaces have to be perfectly clean and wax free.
There is no tape period that will hold jt dive planes on if properly angled at 150+. The jt ones are much larger than say the stock gt3rs 4.0 ones are. They catch a ton of air. Best aero mod on my car for sure. Car when from floaty at 150+ (yes even with gt2 aero) to fill planted.
They work in 2 ways. First the air push on in the canard creates some down force. The second though is the more important. It changes the way the air flows on the side of the car. It move are up over the front wheel well reducing the high pressure there and reduced lift. Then sends the air down the side and over the rear arches and also into the intercooler ducts. This helps keep the air from goon under the car right behind the front wheels. Tons of overall gains minus slightly higher drag.
Overall though, with the size they are, no tape will work. I have 3m and bolts on mine as well as black silicone sealer on the top to fill any voids between the canard and bumper.
Thanks pwdrhound. Don't want to derail this thread, is there a dedicated thread about it somewhere I can checkout? Would like to see more pics and learn more about benefits of these. They only get applied to front only?
[url=https://flic.kr/p/P3vMmM]
