Rear Wing Question
Old Dec 2, 2016 | 03:55 PM
BLKMGK's Avatar
I think the eram kit is the best albeit more expensive replacement. I'm so happy to have a GT2 styled deck but if I was running the hydraulics I'd have his kit for sure!
Old Dec 2, 2016 | 09:57 PM
viprklr's Avatar
viprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond repute
Any options for the fixed Aerokit wing to get it higher off the deck lid.
Old Dec 15, 2016 | 03:26 AM
DaveCarrera4S's Avatar
DaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond repute
thanks for the plug BLK, getting the wing up higher in cleaner air is the name of the game. Exactly why the cabriolet wing extend another inch. This past summer I put on a toth 2 piece splitter, that combined with 4" eRams really made a difference during DE time at Mid Ohio and other tracks. In fact, getting the stock wing up to 4" puts it at roughly the same height as a GT3 or GT4 wing.
Old Dec 16, 2016 | 09:19 AM
HotRodGuy's Avatar
Originally Posted by '02996ttx50
the ebay "fixed wing kit" ($150.00 ) which is a bag of a couple home depot bolts etc has two versions std lift and a 4" lift if you are ok with eliminating the hydraulic functionality.
the best bet for the 4" rise with either a stock wing or a strosek I've seen so far is still carreradave's "eram" rennkit. working electrical up/down AND a 4" lift. looks pretty good to me.
anyone know what bag of bolts I need?
Old Dec 16, 2016 | 12:54 PM
'02996ttx50's Avatar
this is the kit http://www.ebay.com/itm/Porsche-996T...1-YWEQ&vxp=mtr
i'll see if i can find mine and see what all's in it. its still in the box from 5 years ago
Old Dec 17, 2016 | 09:02 AM
rxbike's Avatar
rxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond repute
Theres always this option too : http://www.ebwerks.com/models-996997.html
Give you time to rebuild or consider Dave's kit and get to play with different extension without hacking your hydraulic set up.
Im using it like looking at different frames for one picture as I got a different carbon wing so I get to play a little
Old Dec 18, 2016 | 08:08 AM
Macster's Avatar
Originally Posted by MadWhip
I find that weird
What's weird? Drive down the road at speed with the side window down. Stick your arm out a bit and note the force against your arm. Then extend your arm all the way out. The force increases.
Old Dec 20, 2016 | 04:08 PM
But that's not downforce - it's drag. We have to consider the Bernoulli effect. The faster the airspeed, the more negative lift there is on the inverted turbo wing. Turbulence just in front of the wing messes up this effect.
