Apparent battery short curcuit????
Old Jan 26, 2017 | 05:14 PM
Edward Jones's Avatar
Edward Jones is infamous around these parts
I hope someone has an idea!!!! 2001 911 turbo 30,000, miles. Trickle charger flashed red but never turned green. When I tried to start car it was 100% dead everywhere. Not even a dash light anywhere. Driver door then would not close and latch to lift hood to replace battery is dead, as is engine hood latch. Are these latches electro mechanical?? I cant get in my own car!! Please let me know what I can do. Thanks
Old Jan 26, 2017 | 11:20 PM
BLKMGK's Avatar
Apply power through the cigarette lighter plug, use this to pop a hatch NOT start the car, jump start it or replace battery. There's a power plug in the fuse box at the driver's left foot but I've never had that power point work for opening hatches.
Old Jan 27, 2017 | 04:28 AM
rickw30's Avatar
rickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud of
Do as BLKMGK recommended. There is recent thread on this. Start by changing battery and checking connections.
Old Jan 27, 2017 | 06:21 AM
'02996ttx50's Avatar
to eliminate this kind of lockout in the future, many of us have re-routed the catch wire that sits behind the passenger fender liner so newly positioned, it's still tucked invisibly but easier to access, and lays flush in btw the headlamp and the bumper. then if you have a dead battery, all you'll need is a needlenose plier to snag and pull the catch wire to open the frunk.
usually one "lockout" is enough to investigate this "shortcut" further.
Old Jan 27, 2017 | 04:02 PM
if the battery is fried and defective (not just dead) can i get hood open by applying power to cigarette lighter or control panel???
Old Jan 27, 2017 | 11:02 PM
BLKMGK's Avatar
Yes I think so. My ground cable came completely off the battery and I was able to open mine this way!
Old Jan 28, 2017 | 08:54 AM
spiderman's Avatar
spiderman is a splendid one to beholdspiderman is a splendid one to beholdspiderman is a splendid one to beholdspiderman is a splendid one to beholdspiderman is a splendid one to beholdspiderman is a splendid one to beholdspiderman is a splendid one to behold
This!
If that doesn't work, you can pull the forward section of the wheel well liner on the passenger side front wheel then look forward towards the headlight (but a little more centerline) and find the emergency manual release. It's a small metal cable with a loop on the end. I used a flashlight and a coat hanger I bent up to do the trick. I've also since relocated the tool kit and jack behind the passenger seat on the floor since I had to do all that with the wheel in place since the socket to remove the lug nuts was in the closed frunk.
Old Jan 31, 2017 | 12:37 PM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
Originally Posted by spiderman
This!
that depends, if someone took the front bumper off before, That wire could be anywhere, I found mine in a weird place, I had to take the front bumper off to find it, So i did the trick, I left it in the front fender, behind the mesh, just tucked inside, all I have to do just grab the wire and pull it.
Old Jan 31, 2017 | 01:36 PM
drinaldis's Avatar
drinaldis is a glorious beacon of lightdrinaldis is a glorious beacon of lightdrinaldis is a glorious beacon of lightdrinaldis is a glorious beacon of lightdrinaldis is a glorious beacon of light
OP, if the trickle charger was put on a dead battery it will not bring it back. The trick is to apply a charge via jumping (the battery) to get the trickle charger working. That's how my Battery Tender works.
Old Feb 1, 2017 | 09:15 AM
techweenie's Avatar
techweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant future
I was recently told (had not heard this before) that if your battery drops below 7.5 volts most newer chargers will not feed juice into it.
Old Feb 6, 2017 | 02:37 PM
thanks!! pull out fuse in fuse panel worked well despite defective battery.
I did notice tiny clear tube behind battery with black insert elbow in it that was not connected to anything. Does anybody know what it is for?
Old Feb 6, 2017 | 03:03 PM
32krazy!'s Avatar
acid battery drain tube. if you have a agm battery its not needed
Old Feb 6, 2017 | 06:55 PM
rickw30's Avatar
Replace battery... use tender when not in use.... enjoy your car.
Old Feb 6, 2017 | 11:03 PM
BLKMGK's Avatar
The clear tube is to vent any gas during charging, keeps you from risking a battery explosion. The gas is hydrogen...
