CCW classic center caps
Outside of buying the center caps from CCW directly has anyone had luck with fitting a center cap to their non race version CCW classic wheels? CCW only sells the raised polished style cap and I'm not sure I want to spend 300$ on center caps that I will still need to power coat.
Shawn
Shawn
You could probably get some of those ebay centercaps and modify them to fit. Cheap and would still look good. http://m.ebay.com/itm/NEW-SET-OF-4-P...445?nav=SEARCH
Yea I'm willing to try to make a center cap work for sure, I'm just unsure of what securement style would be best.
I think they're a hyper black or hyper silver color. They just went on the other day so not a ton of pictures. One of my friends did a promotional video for his waxes and my car makes a few cameos.
https://youtu.be/tsUrXvXARso
Are you using hub centric rings or are they machined to fit the hubs? Mine have center caps that are required as centering rings, wondering if I could have some made and run without the caps.
Originally Posted by HotRodGuy
they look great!!!
No hub-centric rings on this set, they mounted up and fit the hub w/o issue.
Shawn
