Albert Motorsport in Germany did my 996 Turbo engine rebuild, a huge loss
Old Feb 7, 2017 | 07:26 AM
  #31
OK51MON's Avatar
OK51MON is infamous around these parts
Ive extended him the offer of mine but yet to have any comeback from him.
Old Feb 7, 2017 | 08:00 AM
  #32
porschecayenne92's Avatar
porschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant future
a new engine for 3.5K was found for him on ebay , he can buy that short block since his heads are ok and send it back to albert motorsport for free build , I think this is the best solution .
Old Feb 7, 2017 | 11:28 AM
  #33
32krazy!'s Avatar
i agree on the block but i wouldnt send it back to that builder
Old Feb 7, 2017 | 11:36 AM
  #34
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
For sure, this had stock studs, chinese rods, stock lifters, and nothing. I build better motors in my kitchen.
Old Feb 7, 2017 | 12:36 PM
  #35
ccjimmyb's Avatar
ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !
That's the best thing I have read so far.
I feel your pain more than I am willing to describe. I am on what I hope is my last teardown which is number 3 .
Old Feb 7, 2017 | 01:34 PM
  #36
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
I'd be interested to see the tops of the piston if there are any signs of detonation.
I read someone say something along the lines of "I've seen stock rods hold more torque than this". Which is true as I've done it with a 996TT and my brothers 997TT, BUT if the rods are cheaply made you can't compare the two.
Now as far as it coming apart 3000km later, it could have been slowly stretching/bending the rods because of the torque (esp if it came in really early) and finally it hit a breaking point. Though seeing the top of the pistons would help to show if there was any detonation, etc. that could have sped up the explosion.
I split a Carillo rod in 2 pieces at 1350+rwhp, the amount of damage is insane even with the Syvecs turning it off the instant it saw an issue (the error code it showed was preignition, but the tune looked dead on). I went back at the logs and saw no signs of oil pressure loss (my first guess as I sat in the middle of the road with an oil slick under the car). At 7600-8000 RPM the rod decided to split and put some holes in the block and ruin pretty much every internal/external thing it could. I think due to not being an HD version of the rod and the stress it had seen during the last 5.5 years it had already became weak and it was just it's time to break.
Old Feb 7, 2017 | 01:55 PM
  #37
B1250Cpe's Avatar
B1250Cpe is infamous around these parts
Originally Posted by OK51MON
Im calling this guy out. Considering he has three posts all of which are based on this thread, I would say he represents Albery Motorsport
I could be a girl, for all you know.
I don't know the owner of the shop, I just stumbled across the same thread in a German board and here.
This happened to be a thread where I feld I could add some value (my German's probably better than yours) hence I registered and posted.
Feel free to use Google-Translator with the German thread (the owner of the shop posted a lot of replies there - nothing that could be said from Kai)
https://translate.google.com/transla...3D1&edit-text=
Old Feb 7, 2017 | 06:39 PM
  #38
Jeanmarcboilard's Avatar
Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !
Why would you join a forum to defend a shop you are not affiliated with. I call bull**** also. What guy has ever said "I could be a girl, for all you know"? I'm thinking this is Alberts wife!?!
Old Feb 7, 2017 | 06:47 PM
  #39
'02996ttx50's Avatar
yeah, odd timing. either way.
Ich rieche Fische.
Old Feb 7, 2017 | 09:01 PM
  #40
brnrdtns's Avatar
Good eye Sean, I didn't catch that. What is the order of oil flow starting at the low oil pump pickup? I would think that the pickup would go to the filter and oil tank first so there wouldn't be any air that might dry the bearing. Isn't that the point of having a dry sump, so there is no oil starvation, GT3 pump or not?
Old Feb 8, 2017 | 12:21 AM
  #41
B1250Cpe's Avatar
You can call whoever you want to - I'll quote myself, as you obviously didn't read what I wrote (I corrected a misspelling that might have prevented proper understanding of the text ).
I highlighted the parts which would answer your question.
This happened to be a thread where I felt I could add some value (my German's probably better than yours) hence I registered and posted.
having heard both sides of the story (especially that Kai didn't let the shop check the car/engine after it failed) makes this imho less obvious...
I was referring to the "guy" part in your previous post.
Apologies for not registering earlier...
I was probably happy to have registered on rennlist 2 weeks ago, otherwise OK5IMON would've "called me out" there as well in the identical thread that Kai started (link)...
Ich rieche Fische.
Old Feb 8, 2017 | 05:11 AM
  #42
at least you have a sense of humor. but what isn't so funny is that anyone capable of deductive reasoning, would easily conclude from reading all of this, that kai has been schtupped.
in any language.
Old Feb 8, 2017 | 05:30 AM
  #43
bsh's Avatar
bsh
bsh is a name known to allbsh is a name known to allbsh is a name known to allbsh is a name known to allbsh is a name known to allbsh is a name known to all
Originally Posted by bsh
Sorry to hear about this failure...
Regarding the snapped rod, can you post a picture of rod bearings and the other top half of the rod? reason I ask is that I snapped a rod on my Evo beacuse the big end of cyl 4 didnt had enough lubrication (drag slicks, min oil level and stock oil pan/pickup...) and the big end seized to the crank and then the rod broke very similar to yours. I had to knock the two half off the crank with a BIG hammer. The rod was blue and the rod bearing was very, very thin...
Just thinking if something similar have happed to you if there have been used wrong clearances on the rod bearing. You have dry sump, so I doubt the culprit is lack of oil pressure..
Does your rod bearing look ok?
Originally Posted by SRM Engineering
The heat marks on the cap indicate a spun bearing. This was very likely a loss of lubrication, and although not posted, this was either cylinder 2 or 5 (last 2 rods to receive oil). OP has a video where you can see/hear exactly when the knock started, was after a sweeping bend at high RPM. Was this motor built with a gt2/3 multi pickup oil pump (probably not). Its unfortunate but if this didnt come apart during intial tune and break in, then it likely wasnt a hardware issue especially at the low power level it was tuned at.
All those commenting without any real world Porsche engine building experience should wait for the few with experience to comment.
+1
We have not seen the bearings nor the second half of the rod (big end).
I understand why my Evo without drysump had oil starvation during launch, but are the 996TT/997TT with the dry sump lubrication known for oil starvation ? I thought the main purpose of a dry sump lubrication are for keeping oil at the oil pump pickup all the time.
Should all TT cars that are used alot on the track be upgraded to the GT2/GT3 oil pump? just asking as I am trying to learn without learning the hard (expensive) way
Could there have been used wrong rod bearing clearance/out of spec big end? I believe this experienced engine builder had it checked, but we all make mistakes...
Sorry if my english sentences is bad, as english is not my main language I am new in the Porsche world/community and I am here to learn and try to help
Old Feb 8, 2017 | 06:04 AM
  #44
B1250Cpe's Avatar
in any language.
That is correct - very few people here are not on Kai's side.
However, the thread on the German board (where Albert posted more stuff and which is now at ~ 250 posts) is not so conclusive (here's a somewhat summary in English).
Old Feb 8, 2017 | 07:01 AM
  #45
agree, it's not "conclusive" and it's a tough read as far as i got.. i will concede that it's not cut and dried or an open and shut case from reading the discourse and what IS clear is that the car should've probably gone back immediately and the variocam solenoid not even touched, once discovered to be faulty.
what is clear ( again ) is that he's been, and may well still be screwed. also appears that any chance at goodwill of any kind emanating from the shop has long since been eliminated.
again, simply following this as best i can? i would remain dubious regarding the quality of the work performed and/or parts used. couple that with the assertion THEY performed the flash/tune?
i dunno man..... still smells of fish AND sucks, either way and my thoughts/comments are not germane. thanks for that link though..
