My car Vs 991.2 TT-S w/ catless exhaust, tune and intake
Old Mar 2, 2017 | 12:11 PM
  #211
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Originally Posted by flewis763
no I said that the turbos have the ability to do 900whp and I was going to push to try and hit that.
I also showed you 3 examples of stock engine k24/20g that did 750whp+ on e85 and stock engine and you still said the highest ever done was 717whp.
again where is the specific post where Bauer claimed 700hp
First he had his boost way up. Stock motor or not you are not going above his power.
Second he had a proefi which you will probably not do because it's 10k with labor.
Old Mar 2, 2017 | 12:12 PM
  #212
996tt550hp's Avatar
Originally Posted by s65e90
I have a similar setup. 4.5 bell intercoolers, 2.5" y pipe, MAFless, full 3" catless exhaust, etc. I have been trying to see how far I can push the stock turbos. I have zero doubt the car will run in the 12x mph in the 1/4 and make over 500hp. Curious to see soon as I will put it on the dyno.
The OP is claiming 530awhp.
No doubt you will make 500hp crank. You will be around 480awhp maybe a little more on a dynojet.
Old Mar 2, 2017 | 12:13 PM
  #213
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
Originally Posted by 996tt550hp
Go find it smart one. Old threads by the OP claiming numbers out of his ***.
Flewis u can't talk much because u blew your motor up. So for a guy that knows what he is doing you must not know what these cars can handle.
mine had and issue with on components failure, a bad boost soleniod. This could happen to anyone and in no way dismisses my knowledge of engines and cars.
I would very much like to know how many performance cars you've personally built, tuned, engines you've assembled, turns you have built, etc. Once you get to even 1/4 of what I have done I'll maybe take your opinions into consideration.
Old Mar 2, 2017 | 12:14 PM
  #214
996tt550hp's Avatar
I never claimed what 1/4 mile I would do. I do half mile runs a lot.
Old Mar 2, 2017 | 12:15 PM
  #215
s65e90's Avatar
s65e90 is infamous around these parts
You can do it much cheaper than 10k. That sounds a little high.
  #216
flewis763's Avatar
25 psi is not crazy boost on turbos that was efficient up into the 30psi+ range. Second I have proefi, if you actually read anything you would remember that.
Old Mar 2, 2017 | 12:16 PM
  #217
996tt550hp's Avatar
Watching a car get everything removed your looking at close to that. A proefi alone are expensive. Labor is awful unless you do it your self. I wouldn't tho
Old Mar 2, 2017 | 12:17 PM
  #218
flewis763's Avatar
Old Mar 2, 2017 | 12:18 PM
  #219
s65e90's Avatar
Labor is crazy, but for an ecu thats 3-3500 that's alot of labor for sure !
Old Mar 2, 2017 | 12:19 PM
  #220
996tt550hp's Avatar
You can install yourself. Not recommend
Old Mar 2, 2017 | 12:20 PM
  #221
996tt550hp's Avatar
Let's say labor cost 130 an hour. Your looking at what people are saying 20hours. Some say 15 hours.
Old Mar 2, 2017 | 12:21 PM
  #222
BauerR's Avatar
BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !
Originally Posted by 6tt550hp
Then what is the argument then on this thread for?
This thread, like all of my previous threads, turn into complete clusters because of you. It's like you're swinging from my nutz.
You have very limited understanding of engines or turbos but talk a game like you helped Corky Bell write Maximum Boost. This is everyone's problem with you.
Know your role, except the fact that you're nothing more than a check writer.
  #223
996tt550hp's Avatar
No way. That's what I'm talking about you can't just say 30+ psi. My turbos after 30psi will not do much after that. So no way a smaller 20g will go beyond 26psi.
Old Mar 2, 2017 | 12:22 PM
  #224
s65e90's Avatar
your math is way off. 20 hours @ 130 = 2,600 + ECU of 3,500 = 6,100. Either way, sure it's a lot of work no doubt. I do most of my own.
  #225
996tt550hp's Avatar
Originally Posted by BauerR
[QUOTe6tt550hp;4613295]Then what is the argument then on this thread for?
Know your role, except the fact that you're nothing more than check writer.[/QUOTE]
Because you make false claims. You started by saying 130mph in the Quarter. Now your saying 120mph in the quarter. Dude go run your car not do ricer fly by on the street.
