KW Coilover suspensions
Old Jan 22, 2006 | 01:27 PM
McBurn4ever's Avatar
..never gets enough..
McBurn4ever is infamous around these partsMcBurn4ever is infamous around these parts
Need advice on a good set up, bump and rebound, when driving both street and track. What settings should I start with..?
Old Jan 22, 2006 | 02:52 PM
MH996TT's Avatar
MH996TT is infamous around these parts
McBurn,
Did you get them installed?
The installation instruction give factory suggested starting points for the damper adjusters.
Correct me if wrong but I think the damping adjustments are for low-speed bumps only. Post your spring rates, shock pressure and ride height if you have that info and I will do the same.
Thanks,
Matt
Old Jan 23, 2006 | 02:21 PM
No, I haven't got whem installed yet..
I have seen the "to start with" recommendations in the manual..
Front Rebound
1,25 turns open
Front Bump
1,00 turns open
Rear Rebound
1,25 turns open
Rear Bump
0,50 turns open
..but I just wondered if there where anyone here that had used their KW's for a while that had another opinion..
Old Jan 24, 2006 | 03:00 AM
03-turbo911's Avatar
Senior Member
Try calling KW and ask to speak to someone who's familiar with the car.
Feelgood MD
Mar 24, 2016 09:35 AM
Feb 24, 2016 01:10 PM
the5
Oct 14, 2015 06:46 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
manfred@loma_wheels
Sep 2, 2015 11:22 AM
