Stiffer Wastegate Springs?
Subscribe
Jan 15, 2006 | 10:05 PM
Can anyone speak of the merits of installing stiffer wastegate springs?
Will they help in quicker spool up?
Reply
Jan 16, 2006 | 12:23 AM
i am using a 1 bar spring in the waste gate actuators
to experiment if i actualy feel the difference
i used my stock waste gates for about a month
and just switched to 1 bar ones two days ago
the difference is HUGE i see 1.2 in second
it feels like a different car.
Boris
Reply
Jan 16, 2006 | 12:53 AM
Nice! That is what I was looking for. Where did you get the actuators and or springs.
Reply
Jan 16, 2006 | 01:26 AM
I have the ultimate motorworks done by Kevin... 1.0 bar spings... billet wastegates.... however.... u cant just put these on a stock k16 and expect great results....
both Calbobba(Boris) and I have the same stage 5 zero clearance turbos.....
its a whole different car......
BTW... my stage 5 tuning package is for sale....
a pic of the turbo with the billet wastegates....
Reply
Jan 16, 2006 | 08:48 PM
I have a K24 factory car. Headers or ported factory manifold and zero clearance turbos would be a nutural progression after the 1 bar wastegate springs.
Although in may case, the turbos would be a relatively inexpensive trade in.
Any interest in selling your wastegate actuators?
Reply
Jan 16, 2006 | 10:26 PM
Do you need new programming when installing the springs?
Reply
Jan 16, 2006 | 10:32 PM
I really doubt it. The turbos are simply spooling faster. Your car has maps for RPM/FUEL/Throttle opening/etc...
Reply
Jan 17, 2006 | 02:36 AM
no u dont need a reprogramm.... stiffer springs hold boost, unlikr the dreaded k24s with stock actautors.
also, u get on boost alot faster.... and the boost doesn not drop... like from 1.2 bars to 1.1 for example in higher gears.
however, if the turbo is not specked out then ur overworking the turbo... and exceeding its efficiency.
so on a stock k16 i wold not suggest it. thats why my stage 5 zero clearance turbos kick ***.
I raced a gsxr 1000 on the highway and he was very surprised when he couldnt pass me up
Reply
Jan 17, 2006 | 02:38 PM
I have used the TIAL upgraded springs on stock K24's. It did not alter peak boost. It did help performance in the midrange. Not a 100% sure but I thought the springs were 10-12 pounds (stock 8 pounds). The Tial springs can be purchased with all of the parts required for the conversion.
Reply
Jan 17, 2006 | 10:16 PM
How much for a set, and how hard is it to do? I have k24's.
Reply
Jan 18, 2006 | 12:06 AM
Jaycla you have PM.
Reply
Jan 20, 2006 | 07:04 PM
Hmm interesting, so this would have no effect on stock k16's, just k24's with over stage 4 tuning and bolt ons im assuming?
Reply
Jan 20, 2006 | 09:37 PM
Quote: Hmm interesting, so this would have no effect on stock k16's, just k24's with over stage 4 tuning and bolt ons im assuming?
No they are saying this helps with all cars that are running higher then normal boost (Stock is around .8, modified is 1.1-1.2 Bar). So even a stg 1 car with a chip upgrade will find this beneficial.
Reply
Jan 20, 2006 | 10:29 PM
Quote: No they are saying this helps with all cars that are running higher then normal boost (Stock is around .8, modified is 1.1-1.2 Bar). So even a stg 1 car with a chip upgrade will find this beneficial.
Yea i kind of figured that.. But my car at stage 2 isnt boosting 1.1-1.2.. I can hit 1.1 in first gear or in a high gear putting a big load on the turbo's when they are spooling, other than that 2nd, 3rd or 4th i pull a steady .9 Do you think i should do this?
Reply
Jan 21, 2006 | 01:38 AM
Im running 1.2 bar springs billet wastegates... I have stock wastegates as well... and what a difference....
boost comes on quicker.... way faster... and it holds peak boost all the time... not like a stock actuator that drops down as Martin described. I get 1.3 bars in all gears.....
if u check evoms ms site.... look under the stage 4 x-50 tuning package.. ull notice that that what they do to the k24s....
Reply
