Will GT2 slave fix power steering res. whine?
I am getting the infamous P/S reservoir whine intermittently when it get hot out. I know the solution is to buy the updated reservoir for around 7-800 bucks. If I do the GT2 slave conversion, does that bypass the faulty check valve, thus not needing to update the PS res? If Im going to spend dough, Id rather upgrade instead of replace with factory parts.
Thanks,
Adam
Thanks,
Adam
GT2 Slave…996 116 237 90 $130
GT2 Master…996 423 171 06 $65
GT2 Assist spring 996 423 081 18 $55
Brake fluid cap…996 355 119 01 $5
GT2 Hose…996 423 377 92 $105
GT2 Clutch fork…997 116 086 90 $180
Flush the old pentosin out really well. Any remnant will destroy the new parts. Fresh dot 4 and you are good to go.
For the install, make sure you check the clearance of the clutch fork in operation, sometimes you'll need to grind down the trans body a bit to make sure it doesn't hit.
Good stuff. Thank you
For sure. Will do. Thx for the advice.
I was able to source a complete gt2 pump and reservoir yesterday for a steal. Only thing I am weary about is the Res part number.. 997-314-220-50. I couldnt figure out if the 997-314-920-50 is an updated number
Thank you. Good info. Hopefully someone finds if useful in the future. I opted to swap out the ps pump and res to an OEM GT unit.
