Pirelli slicks question
Old May 25, 2017 | 12:22 PM
cyneric's Avatar
cyneric is infamous around these parts
Looks good! I have the 305s mounted to my 12" wheels right now and they were stretched too much for my liking. I would be thinking about it during hard corners.
What size wheel are you running?
Old May 27, 2017 | 04:40 PM
cyneric's Avatar
The first picture is the 305/645/18 on the 12" wheels and you can see how far they had to stretch.
The last two pictures are the 325/660/18 and they fit much better.
Old May 29, 2017 | 05:09 PM
Fadi's Avatar
Fadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond repute
Thought 325/660-18 will fit 13J, not so sure anymore, anybody has closer pics in 13J ?
Old May 29, 2017 | 05:50 PM
Jferrante's Avatar
Jferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant future
Here you go - they don't fit even though it doesn't look to bad in the pics it was really stretched
And the comparison is from John its a 335 NT-01 vs the 325 Pirelli the only 325 pirelli that fits on the 13" is the rain tire.
Old May 29, 2017 | 05:52 PM
Fadi's Avatar
thanks, nt01 looking good, but pirelli could have been wider..
Old May 29, 2017 | 07:03 PM
pwdrhound's Avatar
The pirellis run skinny, Yokos are wider. A Yoko A005 slick in a 320/650-18 would be great with a 13 as Yoko lists a recommended 12-14" rim. Pair that with a front A005 250/640-18 on a 9.5 or 10" rim.
Old May 30, 2017 | 04:15 AM
Fadi's Avatar
To be honest as I can run a 660 tall tire in front, might look for 660/660 or 660/680 combo F/R, just to have some more rubber improves grip as far as I know
Old Aug 30, 2017 | 07:24 AM
Fadi's Avatar
Guys anybody tried AVON slicks?
I am looking over
270-650-18 front, real size 25.8", rim 10-11", 302mm wide and 272mm tread
335-645-18 rears, real size 25.75", rim 12.5-13.5", 338mm wide and 330 tread
they come in HARD or MEDIUM compound, I would go for HARD front and rears.
The AVONS are maybe first choice in Europe regarding HillClimb events btw
Other than that I dont know if should go Pirelli, the rear tire seems really narrow for my 10"f/13"r combo
What do you think?
Old Aug 30, 2017 | 09:56 AM
VAGscum's Avatar
According to several sources, 680 won't fit. Might want to see if anyone has done it on a turbo.
Old Aug 30, 2017 | 10:08 AM
Fadi's Avatar
680s work, the problem is the fronts dont accept more than 645-650 using oem fenders. The gap btw front and rears 645-680 is too much for abs, psm etc even for rwd config. Even with psm totally off the abs doesnt like the combo.
One work around is to use 660s in the front instead of 645s so the gap will be acceptable/tolerable for abs ..
Old Aug 30, 2017 | 10:09 AM
Fadi's Avatar
John are the yokos fast enough? Heard they arent that good compared to orher slicks
Old Aug 30, 2017 | 12:17 PM
Fadi's Avatar
Hmmmmm 27-65/18 and 30-65/18 michelins might work too on 10/13 combo ?
Old Aug 30, 2017 | 04:33 PM
z06801's Avatar
z06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond repute
No no, don't use the Michelins then everything else will completely suck
