Another boost leak thread but!!!!
Old May 29, 2017 | 07:50 PM
jpflip's Avatar
Since about two years I got a fault code P0430 that show up about a couple of times per season. Decided to do a good boost leak check today. First I have found the change-over valve, besides the diverter valves, leaking at the base of the outlet tube. A couple of sense lines elbows leaking at the base of the throttle body attachment. But still a leak somewhere near the throttle body. Used my wife stethoscopes, took of the diaphragm at the end of it and only use the tube and the headset and locate a strong leak under the central part of the intake distributor. Took me a while to take out this intermediate piece but there was a small crack in the plastic.... I am now trying different glue to fix that because I don't want a pay $200.00+ for this plastic part....Tomorrow is another day
Name:	Screen Shot 2017-05-29 at 21.25.49.jpeg
ID:	477453   Click image for larger version
Name:	Screen Shot 2017-05-29 at 21.27.30.jpeg
Old May 29, 2017 | 08:03 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
Nice finds. I would have never found that crack.
Old May 29, 2017 | 08:35 PM
jpflip's Avatar
Before the remapping of the ECU I was doing the pressure test at 15 psi and it was holding properly (my max boost was .7 bars (10 psi). But since I boost up to 1.2 bars (17 psi) I have to do the test at higher pressure and many new leaks appear. I do my test at 25 psi, may be it is too high?
Old May 30, 2017 | 01:36 AM
brnrdtns's Avatar
It should all hold.
Old May 30, 2017 | 09:19 AM
gophaster's Avatar
gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !
Nice find! I think 20-25psi for the test is just about right. Personally, I do 20.
Old May 30, 2017 | 02:47 PM
jpflip's Avatar
Ok, job completed , did a last decay and I don't know if it is good or not. Please let me know!
From 25 to 20 it drop in 1:36,
from 20 to 15 went up to 3:25,
from 15 to 10 6:06,
from 10 to 5 10:16,
from 5 to 0 over 16:00 minutes, for a total of a bit over 16 minutes
Is it good?
Old May 30, 2017 | 03:13 PM
Stebo's Avatar
Stebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond repute
Very good.
It's not really about the pressure drop vs time... it's about hearing the leaks at approx 20 psi and addressing them. The slow bleed-off you documented doesn't affect your performance. Rest assured your turbos are not doing any more work than they have to. Green light baby!
Old May 30, 2017 | 03:24 PM
jpflip's Avatar
Originally Posted by Stebo
Very good.
Thanks Stebo!!! Happy to read that! Beer time
