Aftermarket Aero "Style" Front Lip - Any experience?
Old Jun 4, 2017 | 10:35 AM
cgunsch's Avatar
cgunsch is infamous around these partscgunsch is infamous around these parts
Has anyone purchased/installed the aftermarket aero front lip that sells on ebay for ~$100 shipped? Curious on reviews for quality and fitment? OEM from Suncoast is $1k.
I have a factory non-aero lip now (the $330 one on Suncoast). It's starting to fade a bit and was considering swapping out. Either going to do the ebay aero "style" one or the OEM non-aero from Suncoast.
Thanks!
http://www.ebay.com/itm/01-05-Porsch...VWs80y&vxp=mtr
Old Jun 4, 2017 | 10:48 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
Ebay Bayson. It is quality. The plastic underneath extends back a bit to support it. For fitment mine was a bit tight so I had to muscle it on. Extremely pleased.
Old Jun 4, 2017 | 11:30 AM
z06801's Avatar
z06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond repute
You can even set them in the direct sun for a bit before install, helps it to go back to shape after shipping and makes it easy to install.
Old Jun 4, 2017 | 07:04 PM
Slider's Avatar
That looks like the one I have. Quite happy with it.
Old Jun 5, 2017 | 07:01 AM
Turok's Avatar
Turok is infamous around these parts
it differs from the stock aerokit lip (a tiny bit), but in a good way imo.
fitment is good. though it DOES crack easily, whereas the stock will sort of deform and bounce back. I trashed two lips in 3 weeks before I got used to it with my low ride. luckily, it costs almost nothing. will buy one again soon, lol.
Old Jun 5, 2017 | 08:05 AM
Atrox's Avatar
Atrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud of
Get some 303 protectant, it will return faded plastic and protect it quite well. I use that stuff on everything.
You can can also buy the lip off Walmart online store for around $70 bucks.
Old Jun 5, 2017 | 09:11 AM
SeattleTurbo's Avatar
SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !
I have that one. Fit great, looks much better than non-aero lip to me. Cracks easy, dont bottom it or hit it on anything. Mine has inch long crack where it made contact and "flexed" when bottomed out under hard braking at the track.
Old Jun 5, 2017 | 10:15 AM
Third-Reef's Avatar
Third-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond repute
+1 on the 303. Started using it on the inflatable for my trawler. it works great at sealing and protecting from sun and it helps make bug splats not stick quite so well.
Old Jun 5, 2017 | 11:31 AM
z06801's Avatar
I've put this idea up before but it does really help these last much longer. Might even improve aero a bit, for sure if you did a under tray, but if you do scrape, it keeps it from folding under. It's just 1/4" splitter made from abs.Click image for larger version
Old Jun 5, 2017 | 05:52 PM
Third-Reef's Avatar
Just purchased the aero front lip from ebay today. May do the ABS lip also, looks good and is double function, better aero and lasts longer. z06801, Where did you source the 1/4" ABS?
Old Jun 5, 2017 | 11:19 PM
z06801's Avatar
Look for a Professional Plastics in your area they have locations all over if not any plastic supply should have it, You can buy it in a 4'x8' sheet. The lip has about a 1" flat space all around the bottom to attach it, just counter sink the abs and pop rivet or bolt it to the aero lip.
Old Jun 10, 2017 | 01:28 AM
Szpet's Avatar
Szpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud of
Perfect fit after 5min with the heating gun.
Old Jun 10, 2017 | 08:05 PM
BauerR's Avatar
BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !
Have it on mine and even had it painted. Fits like a glove!
ID:	478266   Click image for larger version
Old Jun 10, 2017 | 11:04 PM
Third-Reef's Avatar
Put mine on today, looks much better. Took 15 min.
