Rear tire wear update.
Might be too late for this... if you had caught this earlier could you have remounted the left tire onto the right rim and vica/versa to get more life out of them? I suppose it would depend on mount/balance costs.
I've done that in the past. The only guy I trust with my wheels is an hour from me, plus only does it on Saturdays. Run out of hours in the day...then boom...to late.
the tires should be wearing near perfect with only a minor indicator of the inside. Re-align the car.
Rear toe is set too aggressively. I don't have my Turbo's alignment data sheets handy but when I took the car in to have it aligned I asked the dealer Porsche tech to center the steering wheel and give the car an alignment that would result in even rear tire wear without compromising the car's road manners and stability at speed.
Every time the tech obliged me and afterwards it was not uncommon to get 20K+ miles from a set of rear tires on my Turbo (about the same number of miles I managed from rear tires on my Boxster) with tread wear even across the entire tread face. Might add this was not just some super talented tech. A number of different techs, good, experienced techs I might add, over the years aligned my car and each was able to deliver the same proper alignment.
I am pretty sure my last alignment the toe in was within spec and the camber was slightly off due to lowered H&R street coilovers. I was planning on raising the rear just a bit and swapping out the rear LCA bushings. That seems to be the consensus on fixing inner tire wear. Everything the OP has written perfectly describes my situation, hence the thread revival.
With H&Rs you generally need adjustable toe rods or the eccentric toe rod bushings to be able to get both toe and camber in adjustment. Otherwise you end up with too much camber or (correction) too much toe in. Adjustable LCAs will also fix it but cost more.
If one can follow a Porsche he can see that once underway the rear wheels/tires straighten up and the tires are in full contact with the pavement. It is the toe which can cause the rear tires assume a position underway that leads to the inner edges wearing.
Put a coil-over spacer between the bottom of the spring and the spanner nuts.
http://www.colemanracing.com/Coil-Ov...cer-P4174.aspx
As far as the tire wear, the rear toe is off. Camber, even a LOT of negative, won't wear the tires that much, or that quickly. Also, on the lowered cars, the bump steer does wacky things near the end of the suspension's travel, so it needs to at least be checked (or return the car closer to the stock ride height).
I should probably do a tutorial on checking and adjusting bump steer. It was a weekly check on our Tour Cars.
As for addressing the problem before it gets that bad, keep an eye on tire wear with an accurate tread wear gauge.
The tread depth gauge, tire durometer, and an infrared pyrometer were used religiously every time the car hit the track.
