Plex pbc pro boost controller
Old Jan 12, 2018 | 05:01 PM
Mpsuk's Avatar
Mpsuk is infamous around these parts
Anyone using one of these? What are you thoughts/experiences? Looks like a handy little tool
Old Jan 12, 2018 | 06:25 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
If you are running high HP it is a nice EBC. It has boost by gear.
Old Jan 12, 2018 | 07:04 PM
SeattleTurbo's Avatar
SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !
I've been researching it.... seems nice. Not sure how well it would play with my Cobb tune though is the only thing holding me back.
Old Jan 12, 2018 | 07:16 PM
brnrdtns's Avatar
You can just get a normal EBC for 300.00 or so and switch from your N75. No need for the Plex unless you really have a hot build.
Old Jan 13, 2018 | 05:03 AM
LQQK's Avatar
LQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond repute
You might need a small revision to your Cobb tune, but my plex worked flawlessly with no issues. It really is a great setup, let’s you control external hardware like a second fuel pump or meth and can also take inputs from other failsafes. I can 100% recommend it. Will be back in a couple of weeks if you want to meet up and take a look at mine.
Old Jan 13, 2018 | 06:26 AM
Mpsuk's Avatar
I’m getting a good deal on one with some tial turbos I’m getting so I thought, why not. I had a read up and it seems impressive
Old Jan 14, 2018 | 03:17 PM
would love to get together when you're back, shoot me a message when you're around. your car is getting a lot of positive attention in the warehouse btw...
Old Jan 16, 2018 | 03:01 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
I used it , it's good to tune your car boost based
on a lot of things ! Speed / IATs / gear !!
but not friendly use !!!
but if you know exactly how it work , it's 100% good
Old Jan 16, 2018 | 03:17 PM
Mpsuk's Avatar
I have no idea how it works but reading up on it now. I think it will be pretty cool once it’s set up
Old Jan 18, 2018 | 12:52 PM
Fadi's Avatar
Fadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond repute
get it, if encountering any problem let LQQK know, he will solve it
seriously get it and don't be afraid to get used to it, you will get support here on the forums if needed or directly from Plex, they are very supportive.
Plex is just way above any other EBC I know on the market, not only boost by gear (a lot of EBCs have that) or boost by rpm, but many others including logic and failsafes, multiple presets, compensation by iat/oil temp/engine temp/etc or inputs and outputs etc
Old Jan 18, 2018 | 12:56 PM
Mpsuk's Avatar
I got it. Part of a deal with some tial turbos. Now just got to get manifolds and bigger Exhaust then fit it all up
Old Jan 19, 2018 | 11:31 AM
LQQK's Avatar
With the EBC I’d also recommend adding the aquamist and aem afr failsafe. I feed both of these into the plex. If either trip the failsafe, boost is cut, plus you can turn the aquamist off and boost is automatically lowered to a preset level. Another nice feature is the ability to reduce boost by intake and engine temps. Allows me to dial back the boost to wastegate until the engines up to temp. Lastly, I’d also add a fuel pressure sensor. I have a failsafe that cuts boost if fuel pressure drop below a certain threshold. You will be surprised how often that can happen with only a single pump running.
Old Jan 19, 2018 | 11:42 AM
Mpsuk's Avatar
Thanks for the info. I’m just trying to work out how to fit it up now
Old Mar 21, 2020 | 03:05 PM
OK51MON's Avatar
OK51MON is infamous around these parts
Can anyone help me fit mine?
Old Mar 21, 2020 | 03:22 PM
Mpsuk's Avatar
I’m sure their is an online guide🤔 I’ll see if I can find it and post the link
