Pressure in coolant reservoir when cold
Old Mar 11, 2018 | 04:27 PM
cosworth's Avatar
cosworth is infamous around these parts
Today i was looking at coolant level and since it was few millimeters below MIN i removed the cap to topped it at MAX level , but when i removed the cap some pressure was released and the coolant in tank rise about 1 inch and level return between MIN and MAX . Car was totally cold and indrived for 3 days. Is normal to have some pressure in cooling system on a totally cold engine ? I hope i don't have Head Gasket or cracked head problem .
Anyone have this strange cold pressure in coolant ?
Old Mar 11, 2018 | 07:40 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
they typically have some pressure
Old Mar 13, 2018 | 04:36 PM
HotRodGuy's Avatar
mine operates same way
Old Mar 13, 2018 | 05:21 PM
jpflip's Avatar
In fact it is a good sign if you got pressure in the reservoir! Means no external or internal leaks!!!
Old Mar 21, 2018 | 06:58 PM
fpb111's Avatar
fpb111 is infamous around these parts
Also the level should be very close to Min when cold and very close to Max when hot. If you fill it to Max when cold it will it will push the water out as it heats up and expands.
Slider
Feb 5, 2023 06:56 AM
hph
Nov 15, 2010 10:22 AM
landjet
Jul 19, 2010 07:47 PM
Shay2n10
Mar 10, 2009 06:36 AM
