DIY - Replace Coolant Reservoir
Old Jan 6, 2011 | 07:55 PM
Slider's Avatar
I replaced my leaking coolant reservoir today. Total time was bout 6 hours including time for pictures and lunch. It is not that difficult, it just takes a lot of patience to get your fingers into the tight spots to get parts off. Here is how I did it...
Old Jan 6, 2011 | 09:14 PM
landjet's Avatar
Wow, that old one was really yellow. How many miles on your car? Mine is still white but I did have to replace the cap with the newer part.
Old Jan 6, 2011 | 09:18 PM
Slider's Avatar
The car has 102K kms - (60 K Miles where you come from) It had a slow leak - it wasn't really dripping but I could smell it. There was a little pink spot of hardened coolant under it when I took the old one out.
Old Jan 6, 2011 | 09:33 PM
raineycd's Avatar
Awesome write up!!!!!! Rep for you!
Old Jan 6, 2011 | 09:50 PM
Nor Cal Turbo's Avatar
Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !
Nicely done.
Old Jan 7, 2011 | 05:54 AM
jpflip's Avatar
Excellent Job Slider. Thanks for sharing rep+....
Old Jan 7, 2011 | 09:56 AM
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
yeah be sure to post it up in the knowledge base thread.
Old Jan 7, 2011 | 11:13 AM
XLR82XS's Avatar
GREAT write-up and pics! Rep comin' your way!
Old Jan 7, 2011 | 12:32 PM
jdiesel's Avatar
jdiesel has a spectacular aura aboutjdiesel has a spectacular aura about
Thanks for the write up I might be replacing mine soon.
Old Jan 7, 2011 | 10:28 PM
Slider's Avatar
Good call! Done.
Old Jan 7, 2011 | 10:45 PM
bbywu's Avatar
Excellent DIY!
bob
Old Jan 8, 2011 | 08:12 AM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
Mine just started leaking last mont and had it swapped when theybwere doing my PSS9 install. I guess these things have a weak point on/near then hose fitting at the bottom.
Excellent write up- one of the best I've seen!
Old Jan 8, 2011 | 10:18 AM
Slider's Avatar
Thanks for all the comments!
Here is the old one. I can't really see any holes, but you can see where the trail of residue starts.
Old Jan 9, 2011 | 08:26 PM
Old Bllue's Avatar
Old Bllue is infamous around these parts
Thanks.....
How timely, saw a puddle on the garage floor yesterday and I don't have pets! Thanks for the great DIY instrucitons and photos, what a time saver.
Old Jan 5, 2012 | 08:40 AM
Pmafia's Avatar
Pmafia is infamous around these parts
I see you didn't lower the engine or drain the coolant like I have seen on other DIY's. I like that! Didn't really want to deal with filling with new coolant and "burping" the engine to get the air bubbles out. Was it really difficult muscle the tank out while it was full of coolant? What about the available room without lowering the engine? I thought it was basically required to lower the engine. This DIY is on my list in about 2 weeks.
