Head Gasket or Head lifting ?
Old Apr 8, 2018 | 04:07 PM
cosworth's Avatar
cosworth is infamous around these parts
Thanks for reading and sorry for my english , so i'll try to explain my problem.
My 996 TT k16/24 at 1.1 bar of boost with 60K miles leaks combustion gas in cooling system , but this happened only when i run the car at WOT and under hard loads in 3' , 4' , 5' and 6' gear .
So ,after i drive the car so hard , cooling system remain pressureized for days and days even when completely cold .
So When i check coolant level in reservoir , it is below Min , i remove the cap and big pressure is released (exhaust smell ) so the level rise at MAX again .
i have pressure test cooling system is OK , pressure test cylinders OK , no coolant loss , no oil in coolant and no coolant in the oil or milky oil .
I have checked in coolant reservoir without cap , at idle while car is warming up and no bubbles in coolant .
Again if i drive the car with light loads , at cruise speed or even spirited drive but not at full boost and not at red line in higher gears , this over (exhaust ) pressure in coolant not happens , and when i check the level at cold , level is ok between min and max marks , no pressure or very very small amount is released when remove the cap .
It seems the exhaust gas leaks from combustion chambers to coolant lines only when the pressure in cylinder in very high at peak power stroke , so i figure this is a cylinder heads lifting issue .
I think if it was a blown head gasket , pressure should escape with light engine load too and should the coolant leaks in the cylinders , so coolant in oil should be present.
Car runs great and never overheating .
Is possible this is really an head lifting problem ?
Wich could be the consequences of driving hard ( track days ) a car with head lifting problems ?
Thanks again
Old Apr 8, 2018 | 08:16 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
You lifted a head for sure. You most likely detonated on some bad gas or the bolts went weak on you. The worst thing that can happen is that it will blow water back into the cylinder and hydrolock your motor. That is what happened to me, there was nothing left of the bottom end. You should tear down and should not run this car any longer. Go with some rods and improved head studs. https://www.6speedonline.com/forums/...otor-pics.html
Old Apr 9, 2018 | 12:10 AM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
Check your oil .... Probably will have coolant intermixed
Old Apr 9, 2018 | 12:29 AM
brnrdtns's Avatar
He did say that he doesnt have coolant in the oil. The head stays down at low boost enough to seem ok but it will get worse and you run the risk of destroying everything. Do not drive.
Old Apr 9, 2018 | 07:05 AM
s65e90's Avatar
s65e90 is infamous around these parts
Sounds like head gasket failure between cylinders allowing it to push coolant into the cylinders causing exactly what you describe. Time to take it all apart.
Old Apr 14, 2018 | 02:25 AM
Sveina's Avatar
Sveina is infamous around these parts
Not much point in trying to drive that car any more. Rebuild!
jags911tt
Aug 14, 2009 01:41 PM
Dharn55
Sep 7, 2008 08:26 PM
huskerhoss
May 29, 2006 07:22 PM
gobie18
Jan 21, 2005 11:17 AM
