Exhaust porn....
Old May 9, 2018 | 05:42 AM
  #31
pwdrhound's Avatar
Originally Posted by GT996
Me neither. The main purpose of my post was to congratulate you to your new exhaust and while you were picking on mine (no problem) replying to that. I am not defending anything here. It's an exhaust.
Sorry my friend. I certainly didn’t mean to pick on you or anyone else. I had no idea what or who’s exhaust that is. I just had it saved in my exhaust files along with a bunch of other pictures from about 4 years ago. It certainly appears to be very well made. Cheers!
Old May 9, 2018 | 12:07 PM
  #32
Bill Korea's Avatar
Bill Korea is infamous around these parts
When there's a constriction in the exhaust, the local flow speed increases, and the local pressure goes down - think venturi. The exhaust inlet pressure seen by the engine does go up.
Compared to a straight pipe, the inlet pressure will go up significantly if there is a downstream local restriction, and it will go up a little if there is a downstream local expansion.
Old May 17, 2018 | 06:20 PM
  #33
clsund's Avatar
clsund is infamous around these partsclsund is infamous around these parts
Amazing looking exhaust. drooooooool.....
Old May 22, 2018 | 03:53 PM
  #34
MBB's Avatar
MBB
MBB is infamous around these parts
Just a pure work of art really. Their instagram is never disappointing.
Old May 23, 2018 | 11:15 AM
  #35
BMiller33's Avatar
BMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond repute
The x-pipe design improves scavenging plain and simple, it's been tested ad-nausea. If designed properly with EQUAL length pipes from the cylinder head, exhaust gases cannot slam into each other unless you have cylinders firing at the exact same time. I do agree with our car's exhaust layout/limited space it is a bit different than my old Mustang V8, that point is well taken. Otherwise, to each his own and let's not start a "which oil is best for my car" thread(s)....carry-on.
Old May 24, 2018 | 03:30 PM
  #36
SeattleTurbo's Avatar
SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !
apples and tomatoes.
no scavenging involving cylinder firing order or header primaries occurs post-turbo.... you can get a slight venturi effect reducing back pressure with a well designed X, however the types that smash the flows together between banks/have a larger opening in the X do not have an effective venturi compared to the Unobtainium and EBWerks designs.
Old Jul 1, 2018 | 08:52 AM
  #37
machinegunt's Avatar
machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !
Absolutely beautiful!
sdg1871
Apr 13, 2017 05:33 PM
Dtd350Z
Oct 28, 2003 07:08 AM
