rear wing is starting to leak - options ?
Old May 19, 2018 | 06:11 PM
eds996tt's Avatar
eds996tt is a glorious beacon of lighteds996tt is a glorious beacon of lighteds996tt is a glorious beacon of lighteds996tt is a glorious beacon of lighteds996tt is a glorious beacon of light
my rear wing is starting to fail. Any feedback is appreciated.
my concern is about fit, finish and impact to resale of car.
I don't like the oem system with all the heat it will just fail again.
1. i can update to the electric option ?
2. i can replace the rear with GT2 rear tail but not my favorite
3. has anyone used the Gemballa rear tail from Precision? I like this one.
thanks
Old May 19, 2018 | 09:27 PM
fung0001's Avatar
fung0001 is infamous around these parts
I am selling my right hinge which works perfectly😁
Old May 19, 2018 | 09:29 PM
fung0001's Avatar
I am also looking for some heat insulating solution for my new hinges😁
Old May 20, 2018 | 05:07 AM
DaveCarrera4S's Avatar
DaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond repute
PM me for a 6SO discount code on an eRam Kit. Lots of options and quite a bit less than a factory replacement. As you said, that will fail again with the intense heat in the engine bay.
Old May 20, 2018 | 07:00 PM
Slider's Avatar
I went with this...
Old May 20, 2018 | 07:18 PM
eds996tt's Avatar
I like your wing and it is probably very functional on the track. I may go the electric path because it is less attention when driving on the normal roads. I wish we had a app... normal and full wing ..lol.
what wheels/ sizes and tires are you running?
Old May 20, 2018 | 07:29 PM
eds996tt's Avatar
Dave thanks... I'm now thinking of using the electric for around town and have a wing set up for the track. I was thinking i do the same with my brakes. i use stock when i'm off the track. Before a event I swap in pagid yellow in the front and black in the back.
My only concern is the ecu... will it allow me to do this ? Does anyone see any issues ?
Old May 21, 2018 | 04:48 AM
Our MicroModule warning prevention device supplied with the eRam Kit has you covered both ways.
Old May 21, 2018 | 08:19 AM
Atrox's Avatar
Atrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud of
Went with the erams, couldn’t be happier. Dave is great to work with and available. I was missing an o-ring on the kit and he next day aired it to me! Install was easy and with the speed option it’s really a thing of beauty. He has several sizes, but I went with the 4.75” kit.
Old May 21, 2018 | 08:23 AM
Atrox's Avatar
Old May 21, 2018 | 10:01 AM
Slider's Avatar
I have a bunch of different riser heights so I can tone it down around the city if I want (I never do). I'm running HRE 18 inch - 8.5 in front and 11.5 rear. Currently stock tire sizes.
Old May 21, 2018 | 10:03 AM
Slider's Avatar
I just unplugged the harness and taped the micro-switches. No warnings or codes.
Old May 21, 2018 | 10:36 AM
JoeyG's Avatar
JoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud of
thanks
Kevin at UMW is your solution for a factory look and function. He rebuilt mine, and during the course of the process has spent time with me over the phone to discuss his philosophy, experience, remediation, and issues specific to my system.
In short, through those conversations, it is clear that Kevin has his PhD in Wingonomics.
He's also cost-effective, so if you want an OEM solution with a nearly complete resolution for a poor OEM design without going aftermarket, Kevin is a fabulous option.
Of course the fundamental system retains the hydraulic/syringe style actuation, o-rings, limit switches, and potential for the electric motor to fail, this solution will be long-lasting and very serviceable.
I'm a big advocate for Kevin after experiencing his philosophy, depth of understanding, and pragmatic engineering prowess.
-Joe
Old May 21, 2018 | 04:56 PM
RennKit-Dave's Avatar
RennKit-Dave is infamous around these parts
Originally Posted by Atrox
Went with the eRams, couldn’t be happier. Dave is great to work with and available. I was missing an o-ring on the kit and he next day aired it to me! Install was easy and with the speed option it’s really a thing of beauty. He has several sizes, but I went with the 4.75” kit.
Thanks for the plug! Glad we got you fixed up - I know you waited quite a long time to upgrade.
Old Jul 7, 2018 | 09:22 AM
cgunsch's Avatar
cgunsch is infamous around these partscgunsch is infamous around these parts
My quick fix 😁
