Setting my cams, right this time!
Old May 25, 2018 | 02:27 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
As many of you know I set my cams wrong last year and spent all year driving my car slow. It ran fine but would overboost when getting on it. We have the dial indicators and know that the specs are 110/110 according to sources. The confusion has to do with where you are supposed to set the slop in the variocam. We set it to one side (can't remember if we did forward or back). That was wrong it appears. I have my car torn down and will be borrowing the Stomski dial indicators this weekend. My plan is to use pictures of the 9661 tools to double check my work. I have roughly figured the angles in MS paint which should let me know if I messed up by looking at the slots in the cams in relation to the slots in the plate keys. I will post my progress this weekend.
Old May 25, 2018 | 03:36 PM
brnrdtns's Avatar
Here are the tools.
Old May 29, 2018 | 08:08 AM
brnrdtns's Avatar
I've found one of my cylinders has a leaky valve. I'm going to have to to pull it apart so this is to be continued...
Old May 29, 2018 | 12:18 PM
s65e90's Avatar
s65e90 is infamous around these parts
Sucks after all that hard work. Valve not seating? Hope not bent from having timing off? Sounds like cams were just 180 out?
Old May 29, 2018 | 02:21 PM
if they were 180 out the car would run like crap.
variocam adjuster must be placed on the LEFT hand stop
#TeamAIM
Old May 29, 2018 | 02:26 PM
brnrdtns's Avatar
I'm guessing a valve got bent when we were messing around with the cams. There was a learning curve there. I figured it out by spinning the crank with a wrench, it didn't pop over with compression like the other cylinders. I just have to pull the head and not the cylinders so it won't be bad, just need to get the parts. I could have it back together fairly quickly as long as I have all the parts.
Old May 29, 2018 | 02:30 PM
brnrdtns's Avatar
Yah, it's a sad story.
Old May 30, 2018 | 08:45 AM
s65e90's Avatar
They shouldn't.
Old May 30, 2018 | 08:46 AM
s65e90's Avatar
Old May 30, 2018 | 08:48 AM
They shouldn't.
have u ever tried it?
I have seen it done on a 996TT and it fired on one bank lol
#TeamAIM
Old May 30, 2018 | 08:59 AM
brnrdtns's Avatar
Yes I did see that thread. His intake cams are fixed though, no variocam. I set mine at 110/250 with the variocam on the right hand stop so that it can fall back. Apparently it is supposed to be set so that it can move forward by being set on the left hand stop. When you do the timing plates you set it on the right hand stop but with a different position based on the slots in the plates. That is the source of the incorrect advise that I got.
Old May 30, 2018 | 09:08 AM
do you have the repair manuals there is a whole section in there on cam timing and which directions the cams should face etc?
#TeamAIM
Old May 30, 2018 | 09:13 AM
brnrdtns's Avatar
Yes but it assumes you have the plates.
Old May 30, 2018 | 09:18 AM
plates got cheaper now a days, buy them and avoid the headache. I think maybe 1200-1500 for them. I know its not super cheap but you are spending a lot of time on this.
#TeamAIM
Old May 30, 2018 | 09:38 AM
brnrdtns's Avatar
I was strongly considering getting them but I decided that comparing the results of the dial timing with the angles on the plates as pictured above would work to double check it.
