Odessey PC925 battery?
I've ready many posts, not clear how well this battery works in the 996TT. Can anyone vouch for reliability and starting power with this battery?
I get in some track time, so I'd like to save the weight, but I don't want problems the remainder of the year.
Thanks!
Thanks!
I would recommend the Voltphreaks VPH1200. At 8lbs it’s substantially lighter and more powerful with an auto cutoff which prevent you from getting stranded.
https://www.voltphreaks.com/ssl/cata...products_id=40
whoaaa, that's an expensive battery. (being said from someone whose family has own a battery manufacturer for 80+ years)
Thanks guys, you've got me on some research now...I've also found some possible alternatives, likely because the Lithium batteries are relatively new. It appears that ~30aH and ~1200 cranking amps, and smart controls are the key criteria for us.
-Antigravity 30aH on RS-30 $649 Amazon 11.5 lbs 1200 CCA Rennline advertised.
-EarthX ETX1200 $725 retail 25AH 1200A cranking power. 6.9 lbs No references. 2 year full warranty.
I'm trying to justify the cost A good quality basic tech battery is ~$200 and ~50#.
12-29-2014 11:17 AM
awdbiturbo1
03-14-2014 11:47 AM
drhenrock
12-25-2010 08:59 AM
RCH
03-07-2010 02:15 AM
porschenaround
11-07-2009 10:27 PM
