Excessive oil found in the intercooler (one side only)
Old Aug 6, 2018 | 10:04 PM
porsche996tt_tpe's Avatar
porsche996tt_tpe is infamous around these parts
Hi,
Car is 2002 996 turbo. When changing the coils and spark plugs, the intercooler were removed. The left intercooler has a lot of oil in it, about 300cc of it. The right side intercooler is dry. Is this indicative of a turbo failure or what? Please help.
ps. Boost to 0.6, 0.7 can be achieved.
Thanks!
Old Aug 6, 2018 | 10:28 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
The check valve may be malfunctioning or the turbo bearing could be worn out. Check the turbo shaft for play.
Old Aug 7, 2018 | 09:10 AM
techweenie's Avatar
techweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant future
I had both sides swimming in oil, and you'll likely find oil in the intake plenum as well. In my case it was a failed turbo seal (or maybe both).
Old Aug 8, 2018 | 08:17 AM
Rizwan Misbah's Avatar
Rizwan Misbah is infamous around these parts
Second the failed turbo seal diagnosis. I would pull out the inter cooler, charge pipe and throttle body for a thorough cleaning as welll.
Old Oct 17, 2018 | 10:53 PM
benracinglately's Avatar
benracinglately has a spectacular aura aboutbenracinglately has a spectacular aura aboutbenracinglately has a spectacular aura about
Where is the turbo seal located? I’m familiar with the location of the check valves near the turbo but not the “turbo seal”. Thanks for your help.
Old Oct 21, 2018 | 07:23 PM
Woofie_187's Avatar
Woofie_187 is infamous around these parts
mine did the same **** and the culprit was the engine oil was overfilled i drained all the oil out of the crankcase and then no more oil in my intercoolers, filter or diverter valves. I checked the oil and it was right in the middle after i drained all that out.
pvanosta
Cayenne Turbo
10
Sep 18, 2020 01:05 PM
Hedonistic
Mar 9, 2010 05:16 AM
Aeroresh
Cayenne 955/957
May 16, 2007 08:51 AM
DEETZ
Cayenne 955/957
Jan 23, 2005 05:55 PM
