Just got the Fed Ex from PCNA on 997TT
Old Feb 14, 2006 | 09:38 AM
Doug H's Avatar
Doug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud ofDoug H has much to be proud of
480 hp, 460 torque and 0 - 60 in 3.7 for manual and 3.4 for tiptronic.
Holly ****, 3.4 for tiptronic is dang fast. I almost want one now.
I have rest of specs if anyelse interested.
Old Feb 14, 2006 | 09:40 AM
DJ's Avatar
DJ
Check out the 997 Turbo Forum Doug
Old Feb 14, 2006 | 09:56 AM
Doug H's Avatar
Haha, I forgot there was a 997TT forum. Sorry.
Old Feb 14, 2006 | 02:05 PM
DJ's Avatar
DJ
Doug just in case you are really lazy and don't go to any other section here at 6speed this is for you
997 Turbo
Following the leak of photos over the week, Porsche today officially announced the 2007 911 Turbo. The sixth generation of the 911 series’ top-of-the-range model will be celebrating its world premiere on February 28, 2006 at the Geneva Motor Show and will be available in German dealerships as from June 24, 2006. The 911 Turbo (Type 997) now has an output of 480 hp at 6,000 rpm, 60 hp more than its predecessor (Type 996). The specific output of the 3.6-litre boxer engine thus climbs to a new all-time high of 133 hp per liter of displacement. Rated torque has been increased from 560 to 620 Newtonmeters. The speed range in which this power is available has also been extended. While the previous model’s maximum torque was available between 2,700 and 4,600 revolutions per minute, the corresponding figures are now 1,950 to 5,000 revs.
These improvements are translated into driving performance. The new 911 Turbo with six-speed manual transmission requires 3.9 seconds for the standard sprint from zero to 100 km/h. The coupé reaches the 200 km/h mark in 12.8 seconds. And just 3.8 seconds are all it takes for the most powerful series-built 911 model of all time to accelerate from 80 to 120 km/h in fifth gear. Despite these enhanced performance statistics, Porsche developers succeeded in reducing average fuel consumption by one tenth to 12.8 liters per 100 kilometers.
The 911 Turbo with the optionally available Tiptronic S automatic transmission puts in an even more impressive performance. An optimized setup gives the vehicle the wherewithal to power from zero to one hundred in just 3.7 seconds and to reach 200 km/h after a mere 12.2 seconds.
The Turbo with automatic transmission also has the advantage when it comes to flexibility. In penultimate gear it accelerates from 80 auf 120 km/h in 3.5 seconds. Fuel consumption by the Tiptronic S variant is 0.3 liters lower than that of its predecessor: 13.6 liters in accordance with the EU standard. Both transmission variants have a top speed of 310 km/h.
The vehicle’s flexibility can be enhanced even further with the optional “Sport Chrono Package Turboâ€, available for the first time. Here the driver selects the “sports button†adjacent to the gear lever to activate a short-time “overboost†at full throttle. This increases boost pressure in the mid speed range by 0.2 bar for up to ten seconds; torque rises from 60 to 680 Newtonmeters. The time required by the 911 Turbo with manual transmission for intermediate acceleration from 80 to 120 km/h is reduced by 0.3 seconds to 3.5 seconds.
These performance figures owe themselves to exhaust turbochargers with variable turbine geometry, featuring for the first time in a gasoline engine model. At the heart of this technology are adjustable guide blades, which direct the engine exhaust flow variably and precisely onto the turbine wheel of the exhaust turbocharger. The principle of variable turbine geometry unites the advantages of small and large exhaust turbochargers and leads to a discernable improvement in flexibility and acceleration, particularly at low speeds.
To transfer the available power to the road, the new generation of the 911 Turbo features a redesigned all-wheel drive with an electronically controlled multi-disc clutch. Porsche Traction Management (PTM) ensures variable power distribution to the two driven axles. Depending on the driving conditions, the all-wheel electronics system constantly determine the optimal torque distribution to ensure the best-possible drive. In practice this translates as high agility on narrow country roads, outstanding traction in rain and snow and optimal active safety even at high speeds. These properties make the Porsche Traction Management system in the new 911 Turbo one of the most powerful and, at the same time, lightest all-wheel systems on the market.
The new 911 Turbo’s driving performance is duly tempered by its brake system, which comprises monobloc fixed-caliper disc brakes with six pistons at the front axle and four at the rear.
In comparison with the Type 996, the diameter of the internally ventilated and perforated brake discs at the front and rear wheels has been increased by 20 millimeters to 350 millimeters. As an option, Porsche is also offering its optimized ceramic brake system, PCCB (Porsche Ceramic Composite Brake). The advantages of this high-tech material mean a reduction of 17 kilograms compared to the standard brake system, excellent fading stability owing to consistent friction values and absolute corrosion resistance. The brakes now have a diameter of 380 millimeters at the front axle and 350 millimeters at the rear.
A characteristic design feature of the new 911 Turbo is the modified front end with its distinctive, tautly drawn cooling air inlets. In conjunction with the standard-equipment oval bi-xenon headlights, they define its unmistakable image. The harmonious front view is enhanced by widely placed and deep-set fog lights and by new LED flashers, which are situated in the lateral air inlets of the front end. From the rear perspective too, the Turbo takes on a more powerful appearance. This is due first and foremost to its tail end, 22 millimeters wider than that of the previous model, to which the redesigned wing spoiler element has been aligned. It now slopes downward slightly at the sides to nestle into the contours of the rear fenders. The lateral air inlets behind the doors have also been redrawn and, together with the new air ducts, afford a more efficient supply of cooling air to the charge-air intercoolers.
The basic Euro price for the 911 Turbo is 115,000 Euros. In Germany it is available for 133,603 Euros including value added tax and country-specific requirements. In the USA the 911 Turbo is priced at 122,900 Dollars (not including taxes), and will be available as from July 8, 2006.
In addition to the 911 Turbo, as a special surprise at the Geneva Motor Show, Porsche will be presenting another world premiere: the new 911 GT3. You will receive technical data and photos of this “racing car for the road†on February 28, 2006, the first press day in Geneva.
Old Feb 14, 2006 | 02:37 PM
GENERAL LEE's Avatar
Senior Member
GENERAL LEE is infamous around these parts
I like the clock!
Old Feb 14, 2006 | 03:51 PM
habitat's Avatar
Senior Member
habitat is just really nicehabitat is just really nicehabitat is just really nicehabitat is just really nice
Looks great except for the frt bumper....
I think it would look much better like this!!!!
little photoshop!
Old Feb 14, 2006 | 04:28 PM
Johnfromjersey's Avatar
Johnfromjersey is infamous around these parts
that looks a little better Kerry, but still not pretty, even drunk in a dark bar. still wouldnt want to wake up with this. once you sober up you realize you took home a BEETLE
Old Feb 14, 2006 | 04:30 PM
habitat's Avatar
Senior Member
Good one john!!
Old Feb 14, 2006 | 05:02 PM
buddyg's Avatar
Photoshop the exhuast to come out under the bumper!
Old Feb 14, 2006 | 08:12 PM
fjk143's Avatar
fjk143 is infamous around these parts
The specs speak for themselves alright...
Like the round headlights versus the 996tt ones.
Looks like it has braces on with the LED turn signals. Please tell me they are not sequential!
Don't like the driving light warts - maybe better in person - doubt it.
Will provide a great aftermarket opportunity for front bumpers, rear bumpers and under bumper exhausts.
Wheels look like Mitsubishi designed them - just like the standard 997 wheels look to me.
Old Feb 14, 2006 | 08:33 PM
habitat's Avatar
Senior Member
I don't know how to do that, sorry buddy!!!!
I'm not very good with PS!!!!
Mark @ AIM Performance
46
Aug 29, 2021 12:57 PM
adnanm3
Oct 25, 2016 08:38 AM
17
Jan 22, 2016 07:53 AM
dhahlen
Nov 5, 2015 12:55 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
