When I get my 19's is the correct tire size...
Old Feb 18, 2006 | 11:31 AM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Originally Posted by Griza
Do you have a rough idea of what parameters will cause rubbing or do I have enough clearance to run this size rim and tire without to much issue? There are quite a few people on here that run this size tire and they are dropped/modded so I would imagine there is some room to pplay with. Thank you for the info, I appreciate it........
A turbo with PS2s, the size you mention, mounted on 8.5 42mm offset and 11J 30mm offset, and ride height of 110/120mm (f/r) will be close but with a very firm suspension OK........any lower (or softer) definately need fender prep.....(or raise it or go higher offset). These #s aren't gospel.....only my experience.
Sounds like you already have your wheels coming...........good luck.
Old Feb 18, 2006 | 04:00 PM
Griza's Avatar
Griza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud of
Gregg, many thanks on the info. Iforged actually guaranteed me perfect fitment or I can return them. Obviously I don't want to do that. I gave them close estimates of my setup and they have done many sets of wheels for turbos. I am not worried, I think they will come out fine. Again, thanks!!
Old Feb 18, 2006 | 04:15 PM
GreggT's Avatar
You do understand this Forum requires pics of the finished job ....hope they work out well........nice wheel.
Old Feb 19, 2006 | 12:28 AM
03-turbo911's Avatar
Senior Member
Yeah, post pictures please.
Old Feb 19, 2006 | 12:43 PM
Griza's Avatar
Pics will be posted the minute I get them. Steve at Iforged said about 4-6 weeks.
Here are pics of the ones I had on my S4.......
horsepowerfarm
Sep 10, 2015 06:09 PM
LiquidElephant
Aug 27, 2015 06:17 PM
The Oss
Aug 24, 2015 08:19 PM
L.A.P.
Aug 23, 2015 11:48 PM
ModBargains
Aug 20, 2015 12:28 PM
