Never Enough
Never Enough
EVOMS picked up my car today for the next chapter in the never ending evolution of mods. This phase will include, among other things, the following:
1. EVOMS forged piston kit
2. EVOMS sport exhaust camshafts
3. Port/polish/flow the heads
4. EVOMS high pressure head gasket
5. Bell 4.5 inch intercooler cores with custom end tanks and piping fabricated by EVOMS
6. Quaife limited slip differential
7. Strengthened/reinforced transmission (details to follow)
8. Michelin PS2s
9. Refinements and tweaking to the programming
The head gasket alone should give me an additional 95 HP (that comment was for Jean). Seriously, I am not expecting a quantum leap in power by virtue of these mods. Rather, the pistons and head gasket are strictly for reinforcement purposes. The head work, cams and intercoolers should provide some power gains, as should the modified programming designed to address my unique configuration of components. The LSD should improve traction, and the PS2s should improve handling in most daily driving scenarios (as compared to my Cups, which need to be heated up).
Todd estimates two weeks for the entire project. Thereafter, I have several runs scheduled, including a 900 rwhp Supra and a couple of S/C'd Vettes.
Craig
8. Michelin PS2s
Craig
8. Michelin PS2s
Craig
8. Michelin PS2s
Craig
The head gasket is thicker (about 20/1000) which will drop your compression by three points. I don't put any stock in that 90 hp number. I wouldn't expect any gain from a thicker head gasket. I know it is a strong gasket. I am utilizing one, but I am also cutting the barrels so as to avoid the compression loss.
If you are porting and polishing the heads you should increase the valve size. You can only flow so much air utilizing the stock turbo size valves.
Originally Posted by FAT-911
Didn't you complete major engine work etc some months ago? If so why are you doing this again?
Craig
The head gasket is thicker (about 20/1000) which will drop your compression by three points. I am utilizing one, but I am also cutting the barrels so as to avoid the compression loss.
Craig
Damnit, we keep going in circles, craig, my car is also going down for a cam, alky and some other tweaks. It should be done pretty quickly, though.
Who is the 900hp supra around these parts? I know Braddman from supraforums is local, or are you referring to Alex's car?
Chad, I was kidding about the 90 HP number (re-read my post).
The increased thickness of the head gasket is necessary in order to accomodate the new exhaust cams. Todd and I spoke about the slight decrease in compression. I do not expect any meaningful reduction in power and the superior exhaust cams will more than compensate.
Craig
Craig
CT makes a piston that has the clearance. We designed (mocked it up) it and I believe Todd has used it. It will clear the GT3 intake and exhaust cams. I am guessing the exhaust cam being used is the GT3 exhaust cam or something extremely close.
Let me know when your beast is ready.
Craig
Craig
Craig
