ID Small oil leak
Old Mar 18, 2019 | 11:06 AM
FI_FTW's Avatar
FI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond repute
ID Small oil leak
Finally had my coolant lines fixed and double checking I have no leaks anywhere. All seems good except for a very minor oil leak (1 drop in 4 days) in the circled area in the photo. Anyone know what that is? Hard to see without a lift. Photo is taken from the passenger side (exhaust can be seen on the left).
Old Mar 18, 2019 | 11:20 AM
s65e90's Avatar
s65e90 is infamous around these parts
Look higher. You circled a coolant passage.
Old Mar 18, 2019 | 11:27 AM
FI_FTW's Avatar
That's what I was wondering (not an oil line). I suspect it's maybe a drop or two of spillage when topping off the oil. The filler neck is pretty much right above it.
Old Mar 18, 2019 | 02:31 PM
FI_FTW's Avatar
I'll take a look tonight if I see anything above it. Could be timing chain cover gasket but I doubt it would magically start leaking because the engine was out. They wouldn't have to mess with that doing coolant lines.
Old Mar 18, 2019 | 04:46 PM
'02996ttx50's Avatar
rear main seal leaks begin VERY slowly and are actually numbered by porsche in terms of "severity". (1) being you have some time. etc.
sorry. thats not the right spot for RMS after seeing the pic again.
Old Mar 18, 2019 | 05:18 PM
FI_FTW's Avatar
Yea, way too far back. My guess (hope) is spillage when filling the oil.
Old Mar 18, 2019 | 10:07 PM
FI_FTW's Avatar
I used my phone to take a closer look. Everything seems dry. Sprayed some parts cleaner to make sure it's totally clean and will check again after a longer drive; hopefully just a spill.
Dale D
Cayenne 955/957
19
Aug 12, 2018 06:45 AM
REKX
Apr 13, 2017 08:01 PM
JustinCase
Jan 3, 2016 03:39 PM
scsponger31
Apr 8, 2013 06:45 AM
2001Porsche911
Dec 28, 2008 08:55 PM
