Stereo Help - Replace or Upgrade?
Old May 7, 2019 | 08:16 AM
Slider's Avatar
Yeah, like I said: "Nav" info would not be available...
Old May 7, 2019 | 08:29 AM
gabbys's Avatar
gabbys is infamous around these parts
i hv no idea that what's nav info.
anyway those information are on screen like i said.
Old May 7, 2019 | 10:21 AM
HotRodGuy's Avatar
Originally Posted by gabbys
oil consumption etc
you don't see oil consumption through the dash???
Old May 7, 2019 | 10:34 AM
gabbys's Avatar
i usually put on the bar indicator on dash.
what's wrong with my personal choice of reading information which list on headunit please ?
it's just clean and tidy , and single din or bluetooth receiver mod are good enough for entertainment..
Old May 7, 2019 | 04:58 PM
John@SpeedTech's Avatar
I think you will find that most after-market head units put out more power and better sound than your current head unit. I replaced my HU first and was impressed with just that much of a swap. I eventually continued and replaced everything because it just kept getting better whenever I changed something..
Exactly - on an '02, you can use the OEM wiring, you just need to replace speakers, amp and head unit. I did it and the sound is incredible. I don't use my stereo all the time, but when I do it's fantastic....it's takes a little time for a full swap, but it's a simple conversion process. I used the OEM subwoofer enclosure and just replaced the OEM sub speakers with upgraded units. I mounted the amp and crossovers in the trunk and used a carpeted cover to regain good use of the trunk - lost about 4" of depth. Here are some ideas.....
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old May 7, 2019 | 05:56 PM
BOOSTTT's Avatar
BOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to behold
I'm really happy with my aftermarket system. I just replaced everything and the relocation of the A/C and pocket simply snapped right in. My first upgrade on the car.
Old May 7, 2019 | 06:01 PM
BOOSTTT's Avatar
Here is an idea to get big bass if you want like I do! Easy with old bose box reported and raised in the center with fiberglass and a reverse mounted high power 10" Alpine R series sub.
Bass is deep and can handle anything you throw at it. Just lifts out with the 2 seat clip studs removed.
No problem seeing out the back. I get lots of compliments on the sound. It can pound if you want it to.
Old May 7, 2019 | 06:17 PM
BOOSTTT's Avatar
The huge sub has to angle back a bit to allow enough air space and not to block your vision.
Old May 9, 2019 | 05:06 AM
Bimmeristic's Avatar
Bimmeristic has a spectacular aura aboutBimmeristic has a spectacular aura about
Thanks for sharing!!!!
GT650-25
Jun 13, 2022 01:23 PM
