996 turbo passenger turn signal issue
Old Apr 29, 2019 | 06:30 AM
TTbob's Avatar
TTbob is infamous around these parts
Hi all,
I have a 2003 996 turbo. 2 weeks ago, the passenger front turn signal light went out. I've researched 6speed, rennlist etc, and have tried all the fixes I've seen.
I put a new bulb in, that didnt fix it. I then bent the tabs a little bit on the inside of the housing assembly - this did not fix i right away, I also cleaned the socket. After removing the headlight and putting it back in probably 10 times (while looking for issues), it started working.
Fast forward, I took my car to a car wash and after I got home...the same passenger front turn signal stopped working. I took the passenger bulb+socket and put it in the driver side, it worked fine.
Long story short:
1) I know for a fact my bulb+sockets are good to go.
2) All other electronics/windows/headlamps/tailights etc, they all work.
3) I checked fuses they look fine
4) The male pins on the headlamp assembly of the passenger side headlamp are present and straight.
5) I've tried pushing forward the wires that go in the headlamp female socket (the one that is fixed to the car itself) and they all seem good to go.
6) I've heard the "ground" near the headlamp access hole can cause get corroded etc which can cause headlamp issues. Mine looks clean, but today I plan on Cleaning it out.
7) Does anyone know which of the pins on the headlamp female socket (the one that is fixed to the car itself) correspond to the turn signal? I can check those with a multi meter for voltage?
Any suggestions guys? I assume the car wash caused something to short?
At this point I ordered a new bulb socket (I realize that likely wont fix it but at this point nothing is making sense).
thanks for the help fellas, theres finally good weather here in NY and not being able to drive it is killing me.
Old Apr 29, 2019 | 07:54 AM
XLR82XS's Avatar
It sounds like pressurized water is aggravating the electrical for the turn signal on the passenger side. There may be an issue with the harness going into the main plug that the headlight fits into. (wire insulation, loose pin, rubbed through wire, etc.)
The turn signal inop won't stop it from running. Hey, nobody uses their turn signals in NY anyhow, right!?
Old Apr 29, 2019 | 07:20 PM
TTbob's Avatar
haha true, but unfortunately I need it to pass inspection.
I doused everything in electronics cleaner, bent the socket tabs a little further, scraped the contacts more with sandpaper and the signal works again. Good call on the main plug
Old Apr 30, 2019 | 08:26 AM
XLR82XS's Avatar
Great, glad to hear its working again.
zman2000
Oct 11, 2016 04:47 PM
vrnkc
Oct 14, 2015 06:57 AM
race3
Cayenne 958
Dec 22, 2011 04:54 PM
