If the torque curve was shifted 5-600 rpm or more to the left, I would be more concerned. The SRM turbos seem to spool faster than my K24-18g's, I would prefer that power curve over what I have now.
Don't mash it at low rpm, like when trying to pass someone. Hard to do though because it is fun to feel that boost come on from low rpm.
The Torque curve has shifted 750 rpm to the right. It used to make 550 WTQ @ 3500 rpm -> it now it needs 4250 to make 550 WTQ.
At 4250 the bigger turbos are working, the SRM's make 100 WTQ from 4500 -7000 over the K16's
If I mash the gas at a low rpm, in a big gear, the turbos don't spool as hard as the K16's below 4250. You would think there would be less cylinder pressure with the SRM's below 4250 and therefore lower chance of bending rods.
What am I missing ?
Could be true. You're probably in good shape. I'm just saying that is where you want to be a little more cautious.
HP went from 453 ((K16's) to 580 (SRM's)
TQ went from 550 (K16's) to 590 (SRM's)
Huge improvement. Hoping the rods are not over-stressed with the way the power comes on.
Ahh my bad , couldn’t zoom in far enough on my phone screen. Can post up some pics of what air filter setup you’re running? I know it’s maff less just wonder what you went with.
Do you have filters on your turbos or the stock intake system?
