Cold Start
Old Sep 24, 2019 | 06:09 AM
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
Cold Start
Does anyone know of a tuner that will turn the cold start function off for a reasonable charge? I have a 3" Speedtech exhaust on my car and (100 cell cats and no mufflers). I love the sound, but at cold start it's terrible.
Old Sep 24, 2019 | 02:04 PM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
I have Speedtech 2.5, are you referring to the loud popping, and crackling on cold start? I usually leave my garage closed for the first 30 seconds, during the nosiest part, then open garage.
Old Sep 24, 2019 | 02:15 PM
Macster's Avatar
My 2003 996 Turbo (stock) was a bit noisy at cold start and what I did was just right after start slip the gear box in reverse and back the car out of the car port and drive away. While I generally prefer to let a cold engine warm up some at idle given the car's proximity to other residences I decided to forego the warm up.
It is even worse now with my Hellcat. That thing sets off car alarms a block over. But I do the same thing. Slip the (auto) into reverse which drops the cold idle way down and quiets the engine/exhaust considerably and just ease the car out and get on down the road.
Old Sep 24, 2019 | 02:27 PM
JSBear,
Yes, but I'm sure it's even worse with the 3".
Old Sep 24, 2019 | 02:31 PM
I'm trying to hurry out of the garage as quickly as possible, with as little throttle as possible. I also park in a deck for work, so it's obnoxious when I leave work. My preference it to turn it off.
Old Sep 24, 2019 | 02:59 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
You could try Markski or Sambo (if you want to get a Cobb). Those would be your best bets.
Old Sep 25, 2019 | 07:43 AM
s65e90's Avatar
s65e90 is infamous around these parts
They should be able to shut it off.
Old Sep 25, 2019 | 07:51 AM
pancing's Avatar
pancing has a spectacular aura aboutpancing has a spectacular aura aboutpancing has a spectacular aura about
Try turning your car on without your ac turned on.
Its a bit quieter if you do that, not by a huge amount but see how you like it.
Old Sep 25, 2019 | 02:34 PM
I believe I already asked Sambo and he doesn't do it. Plus, buying a Cobb tuner is a lot of money just to turn off cold start.
Later, Steve
Old Sep 25, 2019 | 03:12 PM
Aktavate's Avatar
Aktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of light
Later, Steve
Did he say why? Not being able to have cold-start delete on a catless car is pretty lame.
Old Sep 25, 2019 | 03:22 PM
JSBear's Avatar
I believe he is running 100 cell cats. My car is louder when I remove the cats, I run 200 cell with my Speedtech. If I left for work early in the morning (like 6 or 7am), I would be hesitant to take the turbo, my car is not my DD.
Old Sep 26, 2019 | 05:41 AM
Yes, I run 100 cell cats and my car is not my daily driver.
Old Sep 26, 2019 | 01:39 PM
Aktavate's Avatar
Roger that, was just curious if its something he CANT do or WONT do as I'm catless and would like to switch to Sam/CobbAP at sometime in the future and was hoping to get cold start coded out.
Old Sep 26, 2019 | 04:30 PM
Macster's Avatar
The cold start is a bit involved.
The intake valve low lift feature is switched on. The engine is fueled richer than even the cold start requires to provide excess fuel which is burned in the exhaust. The excess fuel may be injected with a 2nd injector pulse which is timed to ensure the fuel is carried out the exhaust to avoid the risk of washing the oil from the cold cylinders. At any rate with my stock Turbo I could hear the backfires from the exhaust.
I just found as soon as I had let the engine run just long enough to believe it would be ok -- which really took just a few seconds -- to shift into reverse and back the car out of the carport and drive off kept the racket to a minimum.
Old Sep 28, 2019 | 07:46 AM
Slider's Avatar
I love that short period after the first start of the day when the turbo is so raw and eager. I wish it sounded like that all the time!
