Lowered TT front spoiler scrape protection ?
Old Feb 27, 2006 | 11:42 PM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
Question Lowered TT front spoiler scrape protection ?
Well, I am sure most of the lowered TT guys know the lovely sound of the front lip scraping when you enter or exit a steep incline. My front stock turbo lip is almost gone in the middle front being scraped so many times. I know alot of guys put the C4S lip on, but now since I going to the Techart II front, is there anything to prevent this from ripping the front lip off? I have seen the "boomerang" thing on ebay for the stock turbo front, but does what do people with the Techart front do? Last thing I want to do is rip the lip off or crack the front spoiler on the bottom.
I try to angle in, but sometimes it still hits, and sometimes I have no choice but to drive into some horribly inclined spots...ie: g/f driveway, parking garages..you know what I mean. Thanks for any insight or thoughts.
Old Feb 28, 2006 | 12:01 AM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
you can get a new gf with better driveway at home. If this won't work. You may rise up the front abit with your PSS9.
Old Feb 28, 2006 | 12:11 AM
M3CAB's Avatar
LOL....thought about that! Her driveway sucks....even my stock suspension M3 would scrape.
The only problem with raising the front is that once the Techart is on, it will be lower then the stock TT bumper. Plus my PSS9's are set at ROW specs, so it is not that low.
Old Feb 28, 2006 | 01:28 AM
iLLM3's Avatar
Well your out of luck LOL.. The Techart even dropped from what i saw on John from jersey's hardly scraped, we didnt go up real steep inclines but we did on some moderate sized inclines. The middle is open and doesnt come out to a point like the stock turbo front lip, if your at ROW height you shouldnt have any problem, it seems your only concern is your g/f's driveway?!
BTW what the hell is the "boomerang"?!
Old Feb 28, 2006 | 01:38 AM
Turbo Fanatic's Avatar
Any info on the "boomerang" does it work?
Old Feb 28, 2006 | 08:46 AM
wross996TT's Avatar
Don't get the Techart GTS Type II (with the CF lip)...you will scrape and destroy the lip. With the regular Type II (I removed the CF lip) I have not had any problem with scrapes.
Old Feb 28, 2006 | 10:35 AM
M3CAB's Avatar
I have seen this thing on ebay. Looks like a huge "boomerang" that looks like it attaches to the bottom of the front spoiler. I think it is made of metal. As in funtionality, I assume it works, but not sure if it will save the lip. Not sure exactly how it attaches and where the protection is.
Wross996tt, so you didn't have many problems with the Techart II scraping? It looks so much lower then the stock bumper.
I guess the problem is the g/f driveway, not the car....hmmm....may need to decide which is more important to save!
Old Feb 28, 2006 | 11:52 AM
wross996TT's Avatar
No, Once I removed the CF lip I have not had a scrape. Less so than with the stock lip!
Old Feb 28, 2006 | 12:01 PM
iLLM3's Avatar
Yea that's what i was saying, when i was in a friends without the lip, it didnt scrape on anything even being lowered alot, i was very surprised
Old Feb 28, 2006 | 12:56 PM
habitat's Avatar
Senior Member
habitat is just really nicehabitat is just really nicehabitat is just really nicehabitat is just really nice
Damn, u are in for it with the techart frt...I just had mine taken off and i'm going to the GT2 one...Way easier to replace the bottom lip then the whole bumper...
You just need to take more angles and drive slower...
GOOD LUCK!!!
Old Feb 28, 2006 | 01:41 PM
M3CAB's Avatar
Wross996tt, thanks for the info. Maybe I will end up not installing the lip onto the bumper.
Habitat, thanks for the info also. Did you end up putting that GT2 front on you had for sale a while ago?
Old Feb 28, 2006 | 02:55 PM
WyattTT's Avatar
WyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud of
I suggest a new g/f with a better driveway situation, park on the street, or make her go to your house
Old Mar 1, 2006 | 11:20 AM
bpanos's Avatar
bpanos is a jewel in the roughbpanos is a jewel in the roughbpanos is a jewel in the roughbpanos is a jewel in the rough
You shouldn't have a problem getting up or down any driveway no matter how bad it is. My last 996 which was fitted with the turbo front bumper and lowered 1 and half inches had a two inch ground clearance. The trick to getting in a f-upped driveway is bring your car in at a slant (car must be almost parrallel to sidewalk), as soon as your inside tire touches the bottom of the sidewalk cut your steering wheel all the way and slowly pull in to the driveway. This will cause your outside tire to lift off the ground and raise your font end enough to get into the driveway without scraping. When pulling out of the driveway, reverse at a hard slant with the wheels straight and as soon as your inside tire meets the transition (area where flat part of driveway meets the top of the sidewalk) cut your steering wheel all the way and slowly back up. This will cause your outside tire to raise off the ground giving you the clearance you need. To get your car at the proper slant when reversing, you pretty much have to use the whole driveway so your car is once again almost parrallel to the sidewalk..... so if there is another car in the driveway it might be difficult. It might take some practice but once you get the hang of it you will be so happy. Hope this helps!
Old Mar 1, 2006 | 11:34 AM
ttgangsta's Avatar
ttgangsta has a spectacular aura aboutttgangsta has a spectacular aura aboutttgangsta has a spectacular aura about
I know Xico designed a metal skip plate that he mounted on the bottom of his teachart bumper.
Old Mar 1, 2006 | 09:42 PM
habitat's Avatar
Senior Member
No! ordered a different one...I will have picks up next week...
peace
COBB Tuning
Jan 1, 2025 09:02 AM
3WDistributing
31
Oct 27, 2017 01:26 PM
Enemy
Nov 10, 2015 08:01 AM
gulf gt
Aug 27, 2015 10:27 AM
