Camshaft CEL
Old Jan 10, 2020 | 04:40 PM
sshrum's Avatar
sshrum has a brilliant futuresshrum has a brilliant futuresshrum has a brilliant futuresshrum has a brilliant futuresshrum has a brilliant futuresshrum has a brilliant futuresshrum has a brilliant futuresshrum has a brilliant futuresshrum has a brilliant futuresshrum has a brilliant futuresshrum has a brilliant future
Camshaft CEL
Had my engine rebuilt by Sean West @ Silly Rabbit Motorsport with a whole 3.8 setup and he installed a full ProEFI system. I can't run this in CA due to OBDII requirements. Now that I'm back on the OEM ecu, I'm consistently seeing the following:
What is causing this and can it be fixed without pulling the engine again? Just trying to find out how much of a headache this is turning out to be. With this CEL, I cant smog the car. If I clear the codes, I have to run a drive cycle to set the smog monitors and I pretty much repop the CEL again so I'm stuck.
Old Jan 10, 2020 | 05:25 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
Your timing could be set incorrectly causing your codes. The the timing has a tolerance range and yours appears to be out of range. I know this because I set my timing incorrectly and had the same problem. It is an easy mistake to make. You need a Durametric reading that can tell you exactly how far advances or delayed your cams are. Re timing the cams will require your engine to be removed and cam covers off unfortunately.
Old Jan 10, 2020 | 10:07 PM
sshrum's Avatar
Read somewhere that this could just be a sensor issue. I read about a 997 with about the same mileage as mine that had these codes and they did a sensor change first. I'm hoping this is the problem but I do have a Durametric reader so I could pull the values with that or the Cobb reader.
I've been able to keep the code from popping if I don't push the car hard but you know, it's going to happen more and I don't want to risk ruining something internal.
Thx for the info.
Old Jan 11, 2020 | 01:30 AM
brnrdtns's Avatar
You're probably very close on the timing so it should run fine but you will never pass emissions. If your sensor is bad you get a different code. Do post up what you get from your durametric it is under actual values while idling and it will be one of the cam options that will give you a degree number plus or minus.
Old Jan 11, 2020 | 08:33 AM
s65e90's Avatar
s65e90 is infamous around these parts
Check cam sensors on the valve covers. If bad they will show the variocam out of sync.
Old Jan 26, 2020 | 06:34 PM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
you can check with durametric the deviation of the camshafts / with lifedata then you will see whats wrong
turboslut
Cayenne 958
Jan 20, 2019 09:40 AM
mrmaass
Aug 13, 2016 11:24 AM
tomb18
Sep 9, 2013 08:09 PM
Zeroh
Sep 13, 2010 02:48 PM
andymac
Feb 24, 2009 02:46 AM
