Need some guidance. Axle shaft
Old Mar 5, 2020 | 10:45 AM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
Pretty sure I have a blown CV joint in the axle shaft. Sounds like marbles in a can and has for years and has gotten worse. Not really interested in rebuilding it as I just want a new replacement. Any info on where to go to get one? And 1000$??? Thanks for any information
Old Mar 5, 2020 | 03:19 PM
Slider's Avatar
$700 at the dealer. That's not an after-market item.
Old Mar 5, 2020 | 05:19 PM
'02996ttx50's Avatar
you just reminded me i need to r&r the cv boots. what a PITA ..an awful lot of labor for some (albeit necessary) rubber. argh.
Old Mar 6, 2020 | 11:54 AM
Third-Reef's Avatar
Third-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond repute
When the rear CV joint went out in my 99 C4 at about 120K miles it sounded like someone was tapping on the rear of the car and it would come and go with time and throttle application and change with speed. I found a used set of Turbo axles on e-bay that had 30K on them for $400. They are still gong strong at 200K ( I sold it to a friend).
Old Mar 6, 2020 | 04:31 PM
VGLNTE1's Avatar
Just found a low mile one for 150$. There is a set on there now for 500$.
Old Mar 7, 2020 | 03:18 PM
kamlung's Avatar
5 Year Member
kamlung is a name known to allkamlung is a name known to allkamlung is a name known to allkamlung is a name known to allkamlung is a name known to allkamlung is a name known to all
I just had my Indy reboot my front driver axle. I bought the boots, bolts and nut on pelican for like $50 and he charged me under $300 in labor to remove and rebuild the axle.
Old Mar 7, 2020 | 07:57 PM
Third-Reef's Avatar
I would replace both as a pair. It might induce some strange yaw or shiftyness in the rear under acell and decell if the axles had varying amounts of play
Old Mar 7, 2020 | 08:02 PM
VGLNTE1's Avatar
Anyone know off hand what size the axle nut is on the wheel hub? Want to make sure I have it before I dig in. There isn't a single YouTube video of a rear shaft for a turbo.
Old Mar 7, 2020 | 08:37 PM
kamlung's Avatar
5 Year Member
you can easily pop off the wheel cap with the wheels still on and stick a socket in to check the size
Old Mar 8, 2020 | 08:59 AM
VGLNTE1's Avatar
Not with my aftermarket wheels
Old Mar 8, 2020 | 10:38 AM
jpflip's Avatar
The size of the socket needed to remove the axle nut is 32mm and the torque of this nut is 460 ftlb.
Old Mar 8, 2020 | 11:11 AM
Stebo's Avatar
Stebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond repute
I have the socket at the house, I can check later today. My gut says 32mm but let me check
Old Mar 8, 2020 | 04:40 PM
Stebo's Avatar
Yup 32mm
Old Mar 8, 2020 | 07:24 PM
VGLNTE1's Avatar
Thanks guys. Went to replace the rear today and decided to look at the fronts. Both ends of the front CV is blow and crap all over. Sigh.....oh well, only the 2nd thing that has needed replaced in 120000 miles!
Old Mar 12, 2020 | 06:35 AM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
I just did both of my fronts. These things are super reliable. They are the woodstoves of performance cars! I spent more in a year with my F355 that I have in 18 years with my Turbo!
